Need immediate help Win 10
Go to solution Solved by limegorilla,
1 minute ago, Bradl79 said:
yes
Once you've clicked new it should come up with a window, follow the instructions and create the partition. Then install windows to the partition and go from there
6 minutes ago, xDylanio said:
So i reset my win 10, but now that i want to install windows on my 250 gb SSD it says
Just highlight the disk, then press the delete button. Then, once formatting is complete hit the new button and follow the prompts. Once done, select and continue the setup
Bow down to me humans.
I can't help if you don't quote me. How am I supposed to know if you need my premium support? Now starting at £399.99 a year.
Also, be a sport and mark the correct answer as the correct answer. It will help pour souls in the future when they are stuck and need guidance.
"If it works, proceed to take it apart and 'make it work better.' Then cry for help when it breaks." - Me, about five minutes ago when my train of thought wandered.
Remember kids, A janky solution is still a solution.
have u tried to Delete (not Format) all partitions on that drive 1st then create New on that drive, make sure u don't delete other drives
for instance if u are trying to install windows 10 on Drive 0, then delete all partitions on Drive 0, then click on New
My PCPartPicker - 1st Build
Alright i think i guessed it. What i did Is i deleted all of the partitions i already had, and then just hit the install button on my ssd and it worked
CPU - i7-4790k
GPU - MSI 980 Ti
Mobo - MSI Z97 Gaming 5
Memory - 32 GB DDR3
Storage - 3.4 TB
Full List : https://pcpartpicker.com/list/sPgN8d
I did something similar, i deleted all the partitions i already had
CPU - i7-4790k
GPU - MSI 980 Ti
Memory - 32 GB DDR3
Storage - 3.4 TB
Now highlight a unpartitioned drive and select new
yes
