got to the wiring of my build and my 24 connector it was more like 20pin with a 4pin. and my cpu connector one side is a full 8 pin and the other is (2) 4 pins
which side do i plug into my motherboard and which one do i plug into my psu and does the cpu plug go in the slot labeled eatx12v?
https://linustechtips.com/topic/739744-first-build-help/
20+4 is on the same cable, put it in the 24 pin connector. As for the other it depends what board you have, can you attach a picture or tell us the exact model number? Some are 4 pin atx others are 8pin, normally in the top left edge of the board. Also what PSU is it?
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/739744-first-build-help/#findComment-9381798
