i bought the cryorig h7 and when installing it onto my motherboard the x-bar holes line up but one hole is hovering above the screw and the rest are touching ready to be screwed in. what do i do? do i screw in the 3 touching and see of the other one comes down so i can screw it in?
https://linustechtips.com/topic/739617-first-build-problem/
you should screw all 4 screws down only a little to allow them to attach and then tighten them progressively
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/739617-first-build-problem/#findComment-9380745
you should also tighten these things in a star pattern, top left, then bottom right, then top right, then bottom left, to ensure even pressure at all times.
Ryzen 9 3950x - 64 GB DDR4 - NVME 980 pro SSD - EVGA RTX 3080 FTW Ultra - FAD CASE
Full custom loop / links below out of date
LTT Build Log | PCPP Build Log
_____________________________________________________________________________________________
Sorry if I stop responding, I've probably gotten busy as I mostly am only on here while working.
https://linustechtips.com/topic/739617-first-build-problem/#findComment-9380771
