Hi!
My friend wants a pc that can run CSGO and Dota 2. Specifically tied to those games. I tried putting up one for him ended with this:
Intel i3 6100
MSI H110M Pro VH
Kingston HyperX Savage 2x4 8GB
XFX RX 460 2GB
Adata SP550 240GB
Tecware Raiden
Seasonic M12II-520W EVO
Since CSGO and Dota aren't really heavy games to run, I thought these would be enough for his budget (PHP 20-25k)
CPU: Intel Core i5-6600k 4.4GHz | Motherboard: Asus ROG STRIX Z270F Gaming | Cooler: Cryorig H7 | RAM: GSkill Ripjaws V 8GB 2x4 3200 MHz | GPU: MSI GTX 1070 Gaming X | PSU: Seasonic G-550w 80+ Gold Certified, Semi Modular | Storage: 250GB Samsung 850 EVO, 1TB Western Digital Caviar Blue | Case: NZXT S340 Elite (Black/Red) | Monitor: BenQ XL2411 144hz | Keyboard: Corsair STRAFE RGB Cherry MX Silent | Mouse: Corsair M65 Pro RGB
I'd like to make a Chemistry joke, but all the good ones ARGON. *nudgenudge *winkwink
https://linustechtips.com/topic/739202-build-for-a-friend/
@herman mcpootis what do you think?
https://linustechtips.com/topic/739202-build-for-a-friend/#findComment-9376694
it should be fine for CS:GO
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/739202-build-for-a-friend/#findComment-9376701
3 minutes ago, GGWP1337 said:
Well, if it's okay for CS:GO it should also be fine for Dota, I play it myself, but just on an older i5
Dota doesn't require much :)
That's what I thought too but with the 7.0 update, Dota 2 is effed from bottom up. FPS drops, skipped frames etc. Anyway, I think that can be fixed with updates. I havent played dota 2 in a while so i have no idea how it runs these days.
https://linustechtips.com/topic/739202-build-for-a-friend/#findComment-9376718
I'd see if the mobo bios support kabylake and get the g4560 instead, use the money saved on a gtx 1050/ti.
https://linustechtips.com/topic/739202-build-for-a-friend/#findComment-9376720
It doesnt.
https://www.msi.com/Motherboard/H110M-PRO-VH.html#hero-overview
https://linustechtips.com/topic/739202-build-for-a-friend/#findComment-9376723
Just now, FRN said:
it can support the Kaby lake CPUs but you need a BIOS update
and yes you still need a Skylake CPU to do the BIOS flashing
https://linustechtips.com/topic/739202-build-for-a-friend/#findComment-9376729
I'd hate to tear down my PC for him. lol.
https://linustechtips.com/topic/739202-build-for-a-friend/#findComment-9376734
11 minutes ago, FRN said:
It'll likely need a bios update, or get one from november 2016's batch or later as the most kabylake supported bioses were released at around october.
https://linustechtips.com/topic/739202-build-for-a-friend/#findComment-9376764
I'll go with a B250M since the budget will allow.
https://linustechtips.com/topic/739202-build-for-a-friend/#findComment-9376791
