Hot fittings?
Go to solution Solved by Lurick,
Can you define hot? Like too hot to touch or just warm?
They will conduct heat from the loop and the loop temperature shouldn't go above I think 50C to 60C or so. They tubes should be warm, when people say the loop should be cool they mean in the 40C range which will still feel warm/hot to the touch.
So, my fittings gets hot when I'm gaming... why? I read online that the loop temp should stay low, I have plenty of rad space, my components are cool enough, but my fittings become hot and my tubes warm... am I doing something wrong here?
whats in the loop: i7-6700K @4.7GHz 1.38V
                            GTX 1080 G1 Gaming
                            240mm radiator
                            360mm radiator
Record holder for Firestrike, Firestrike Extreme and Firestrike Ultra for his hardware
Top 67 for TimeSpy and Top 26 for Timespy Extreme
Intel i7 10700 || 64GB Kingston Predator RGB || Asus H470i Strix || MSI RX 6700XT Merc X2 OC || Corsair MP600 500GB ||  WD Blue SN550 1TB || 2TB Samsung QVO || EVGA 550 GM || EK-Classic 115X aRGB CPU block - Corsair XR5 240mm RAD - Alphacool GPU Block - DarkSide 240mm external rad || Lian Li Q58 || 2x Cooler Master ARGB 120MM + 2x Noctua  Redux 1700RPM 120MM  || Terramaster D4-320 HDD enclosure w/ 1x 8TB 256mb cache 7200rpm Ironwolf & 1x 4tb WD Red 256mb cache 7200rpm
https://linustechtips.com/topic/738906-hot-fittings/
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/738906-hot-fittings/#findComment-9373492
It's the liquid's job to carry heat away from components so of course it's going to get warm. Fittings are typically metal, so they pick up heat more than other parts of the loop.
As long as your temperatures are fine, nothing is wrong. The tubing in my loop is warm too.
https://linustechtips.com/topic/738906-hot-fittings/#findComment-9373495
like very warm at touch, you wont burn yourself, but Id see it be around 40C for sure
https://linustechtips.com/topic/738906-hot-fittings/#findComment-9373496
That's fine and about expected.
Prior Build Log/PC:
https://linustechtips.com/topic/738906-hot-fittings/#findComment-9373499
Thank you, wasn't sure! first time I ever noticed it in the 3 years I've liquid cooled!
https://linustechtips.com/topic/738906-hot-fittings/#findComment-9373502
                            GTX 1080 G1 Gaming
                            240mm radiator
                            360mm radiator
bit unrelated but what are your CPU and GPU temps and fan speeds? I have the same loop with bigger rads and slightly lower voltage so I am just wondering :)
5900X
MSI MEG X570 Unify
32GB DDR4 Corsair Vengeance
RTX 3080
Dark Base Pro 900
Corsair RM1000i
https://linustechtips.com/topic/738906-hot-fittings/#findComment-9373508
CPU Idle's at 28C, and games between 45C and 55C (depending on the game), reaches 65 in stress testing (maybe 68-70 spikes) and the GPU idles at 32-34C (no idea what I did wrong here to have it idle higher) but games at 45C-50C, depending how long Ive been gaming... (usually at 43-45C but can get to 48-50 after 3+ hours of gaming)
All my radiator fans are BitFenix Spectre Pro running at 1260RMP while gaming (their max speed) and 860RPM while idle, just to quiet it down a bit (not that it's noizy anyways)
My blocks: Barrow Energy 115x CPU block
                  BitsPower GTX G1 Gaming 1080 special edition block
My Rads:   DarkSide 240mm slim and 360mm slim
https://linustechtips.com/topic/738906-hot-fittings/#findComment-9373522
Completed Build in PCpartPicker
(it has some pictures)
https://linustechtips.com/topic/738906-hot-fittings/#findComment-9373524
damn, I am jelly. I guess I lost the silicon lottery with my 80+ degrees in stresstesting when I have 360mm and 420mm rad
Thanks for the info!!!
5900X
MSI MEG X570 Unify
RTX 3080
Dark Base Pro 900
Corsair RM1000i
https://linustechtips.com/topic/738906-hot-fittings/#findComment-9373534
Maybe not, what kind of block do you have? maybe you could reseat it with more thermal paste? did you open it? (I once opened mine and place the pressure plate the wrong way and it ruined my temps, i didn't realise until months later when I cleaned it up...)
Usually having a lower voltage should mean lower temps...
https://linustechtips.com/topic/738906-hot-fittings/#findComment-9373539
I did reseat it multiple times with no improvement at all. I didnt open the block so that should be fine too. I think my only option would be to delid
5900X
MSI MEG X570 Unify
RTX 3080
Dark Base Pro 900
Corsair RM1000i
https://linustechtips.com/topic/738906-hot-fittings/#findComment-9373548
which block are you using?
https://linustechtips.com/topic/738906-hot-fittings/#findComment-9373667
EK-Supremacy Evo
Very odd, that's a great block...
https://linustechtips.com/topic/738906-hot-fittings/#findComment-9373677
Exactly. I saw very similar temps with NH-D15... In the end, I gave up on it and I dont have it overclocked just to avoid those temps :D I'll delid it when I find some time and hope it will help
5900X
MSI MEG X570 Unify
RTX 3080
Dark Base Pro 900
Corsair RM1000i
https://linustechtips.com/topic/738906-hot-fittings/#findComment-9373700
