Need help with "brands"?
Go to solution Solved by Guest,
different cooling solutions and extra (OC) features, the GPU itself comes from Nvidia/AMD and is always the "same" (sometimes they are better binned but it depends on product)
Pretty much this. Also warranty and customer service is different.
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/738831-need-help-with-brands/#findComment-9372861
