Hello hive mind,
I'm a first time PC builder looking to get a general idea of what I can get for my money.  I'm not looking to buy immediately just get an idea of what to look for.  I tried PC part picker and thought I would see what people thought of my current list.  I'm relatively new to this (this is my first build).  I currently am running a 5 year old MacBook Pro.
- Budget: $1,000+- a bit depending on what I can get
- Zip Code or Location: US
- Specific Use: Some mid-range gaming (LOL, CSGO, Skyrim) but nothing crazy heavy
- Any preferred components?: This is what I was looking at, but am not tied to anything https://pcpartpicker.com/list/fKXyZ8
- Any spare parts you can re-use?: Nope
- Overclocking your processor?: I had thought about it, would like to hear opinions on this especially since I am a newbie. (I had looked at this list for overclocking so this might be a possibility, it is just a bit over what I was hoping to spend https://pcpartpicker.com/list/jMZwHN - only real change are motherboard and CPU)
- Need an Operating System?: Yes, but would be willing to buy separately from the budget.
- Need a Monitor? / Mouse? / Keyboard?: No
- Need a Wireless Card or Adapter? Would prefer built in WiFi otherwise yes.
Other Useful Info
- Preferred Case Features (Ex: Color, Side Window, Flashy): Fractal Design Black Nano S - definitely think I want a smaller form factor and really like the look of this case
- Number of Monitors: 1
As of right now I am just really looking at opinions on the list and if there is anything I should definitely change or look at instead.
Thanks everyone!
https://linustechtips.com/topic/738733-first-build/
1 minute ago, jaximusrex said:
The Nano S by Fractal Design in Black
ummm - telling you right now, mini itx builds for z270 that look nice normally don't go very well - and mini itx is for the most experienced of builders - not first time- you're cable management will literally take 20 hours or just really shitty
https://linustechtips.com/topic/738733-first-build/#findComment-9371616
2 minutes ago, jaximusrex said:
That is the one thing I was worried about was being inexperienced and doing a small build.  But I don't think I want a Mid-Tower PC.  I'll have to think on it.
how does a micro atx mini tower do? it's maybe at most 10 cm larger than mini itx -
https://linustechtips.com/topic/738733-first-build/#findComment-9371645
CPU: Intel Core i5-7600K 3.8GHz Quad-Core Processor  ($238.75 @ OutletPC)
CPU Cooler: Corsair H100i v2 70.7 CFM Liquid CPU Cooler  ($99.99 @ B&H)
Motherboard: ASRock Z270M Pro4 Micro ATX LGA1151 Motherboard  ($119.99 @ SuperBiiz)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2800 Memory  ($96.99 @ Newegg)
Storage: Sandisk SSD PLUS 240GB 2.5" Solid State Drive  ($74.99 @ B&H)
Storage: Hitachi Ultrastar 1TB 3.5" 7200RPM Internal Hard Drive  ($39.99 @ Amazon)
Video Card: Asus Radeon RX 480 8GB ROG STRIX Video Card  ($244.99 @ Jet)
Case: Cooler Master MasterCase Pro 3 MicroATX Mini Tower Case  ($74.99 @ Newegg)
Power Supply: Corsair CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($40.98 @ Newegg)
Total: $1031.66
Generated by PCPartPicker 2017-02-15 20:50 EST-0500
a bit over budget - i would go for fully modular psu - so bitfenix whisper m is decent or evga gs or g2
https://linustechtips.com/topic/738733-first-build/#findComment-9371648
international racing driver
My Build
i5-7600k
hyper x fury 16gb (2133)mhz
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
agon 1440p 144hz tn monitor
corsair strafe mx silent KB
corsair void rbg (wired)
razer mamba te with firefly mouse pat
ps4 controller using ds4 windows
https://linustechtips.com/topic/738733-first-build/#findComment-9371651
Well, if you want a console size pc, (like im planning to build too) i recommend, this, but is overbudget. so you need to think.
CPU Cooler: CRYORIG C7 40.5 CFM CPU Cooler  ($29.88 @ OutletPC)
Motherboard: ASRock Fatal1ty Z270 Gaming-ITX/ac Mini ITX LGA1151 Motherboard  ($159.99 @ SuperBiiz)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400 Memory  ($97.99 @ Newegg)
Storage: PNY CS1311 240GB 2.5" Solid State Drive  ($79.99 @ Best Buy)
Video Card: Zotac GeForce GTX 1070 8GB AMP! Edition Video Card  ($385.70 @ Jet)
Case: Fractal Design Node 202 HTPC Case  ($78.99 @ SuperBiiz)
Power Supply: Corsair SF 600W 80+ Gold Certified Fully-Modular SFX Power Supply  ($119.99 @ Corsair)
Total: $1191.28
Generated by PCPartPicker 2017-02-15 20:53 EST-0500
https://linustechtips.com/topic/738733-first-build/#findComment-9371669
Dont worry, about it. if you take your time and with patience and common sense you will do it. also if you're lost youtube is your #1 ally on building pc of any size. that's what i did and made a few small mistakes but i learn about it and i can say with certainly that i can build a pc.
I started first with a build for my father, and now he's happy about it. is just a humble build of 400$. use a G4400.
and im impresed that can run BF3 but a low settings 40+FPS at 800x480. (yeah is a mess but i did expect that).
https://linustechtips.com/topic/738733-first-build/#findComment-9371732
