Hi, Im building a Gameboy zero (raspberry pi powered Retropie console).
I ran into an issue with the screen I'm using, wondering if anybody else has had the same issue.
The colours are washed out to the point of the screen being almost totally white.
It's a backup camera screen for a car from eBay. Lots of projects have used them, wondering if there's anything I can do to fix mine.
Thank you.
https://linustechtips.com/topic/738618-screen-for-raspberry-pi-project/
all i can think off is in OS collor corection/balance if there is something like that
Builds:
Was it like that from the start or did it get worse?
I guess its defective and would return it if possible.
UI/UX Designer
CPU:
Intel i5 6600k @ 4.4GHz, Noctua NH D-15, GPU: MSI GTX 970, RAM: HyperX Fury 32GB (2x16GB) DDR4, MoBo: AsRock Z170 extreme4 ATX, Storage: 250GB Samsung EVO SSD + 128GB Toshiba M.2 SSD + 1TB WD Blue, PSU: Antec 650W, Fractal Design Define S
Started like this.
On 2/15/2017 at 9:48 PM, tlink said:
it looks like the satnav is completely burned into the screen?
Thats the raspian OS.
24 minutes ago, Thunderpup said:
adjust the voltage pots?
Tempted, what am i gonna do? fudge it more? :P
I only see one pot though, can you see more?
i only see one as well.
this is by no means my area of expertise, but i've watched plenty of videos where screen display issues like yours was resolved by adjusting the pot.
So i'd give it a try but go slowly. If it works then great and if not then you are back to square uno.
