Thinking on building a new pc in the beginning of this summer and as most of people who are new to that kind of stuff i got confused on which power supply unit do i need.
These are the parts im thinking on getting:
Asus Maximus IX Formula LGA1151
Intel Core i7-7700K 4,2Ghz
G.Skill Trident Z DDR4 3400Mhz 4x8 32Gt
Cooling NXZT Kraken x62
Case Corsair Crystal series 460x RGB
Samsung 850evo SSD 250gt
Seagate 1TB barracuda sata 6GB/s
Asus Geforce Strixgtx1060-O6g-gaming
So and with the psu i was considering
Corsair AX Series, AX860i or would it be enough of the AX760
Im also considering on going SLI
Thank you for your help and time
https://linustechtips.com/topic/738586-help-with-the-psu/
Wait for Ryzen and Vega
Quote or tag if you want me to answer! PM me if you are in a real hurry!
Why do Java developers wear glasses? Because they can't C#!
My Machines:
The Gaming Rig:
-Processor: i5 6600k @4.6GHz
-Graphics: GTX1060 6GB G1 Gaming
-RAM: 2x8GB HyperX DDR4 2133MHz
-Motherboard: Asus Z170-A
-Cooler: Corsair H100i
-PSU: EVGA 650W 80+bronze
-AOC 1080p ultrawide
My good old laptop:
Lenovo T430
-Processor: i7 3520M
-4GB DDR3 1600MHz
-Graphics: intel iGPU :(
-Not even 1080p
https://linustechtips.com/topic/738586-help-with-the-psu/#findComment-9369863
Oh and Power Supply Unit = PSU, not PCU :D Just FYI
My Machines:
The Gaming Rig:
My good old laptop:
Lenovo T430
-4GB DDR3 1600MHz
-Not even 1080p
https://linustechtips.com/topic/738586-help-with-the-psu/#findComment-9369873
So and with the pcu i was considering
The power supply that you want is a good unit. It's tier 1 on this thread.
Everything looks good. You have time to consider the coming Ryzen CPUs, which could give you what you want at a lower cost.
https://linustechtips.com/topic/738586-help-with-the-psu/#findComment-9369916
If like most people, you're building this PC for gaming, I'd suggest dropping down to an i5 7600k and getting a GTX 1070 instead. The Maximus Formula is also a pretty expensive board so you should probably think twice before getting it. 3400Mhz RAM won't help unless you run multiple virtual machines or something. For the PSU, I'd say even an EVGA G2 650w will do
https://linustechtips.com/topic/738586-help-with-the-psu/#findComment-9369957
Ill go with the intel
Im more of a person whod pay more or much more to get the things that are surely good
https://linustechtips.com/topic/738586-help-with-the-psu/#findComment-9369973
Just a couple of things... I would definitely encourage reading some of the threads on the Cases and Power Supply section of the forum.  As for PSU, either the 860 or 760 will supply more than enough power for the whole system since the load figures are only around 380 Watts for this build.  Also, I would read up on whether you can even SLI a 1060.  My understanding is that you can only run two 1060's through the PCI-E Bus and they don't have direct SLI enabled.
https://linustechtips.com/topic/738586-help-with-the-psu/#findComment-9369978
I know not much about the stuff im just thinking to run two of 1060 or maybe later ill change to something better
Maybe 1080 or even also two of them
https://linustechtips.com/topic/738586-help-with-the-psu/#findComment-9370060
The ram would help me with my school projects in which we use the virtual machine
https://linustechtips.com/topic/738586-help-with-the-psu/#findComment-9370079
Are you going to dedicate a 1060 to each VM? If not, you're probably better off just getting a 1070 or 1080 right now since the 1060's don't have the plugs to use an SLI bridge.  As for the VMs that you might be running, I think the major limiting factor that you'll encounter with those are going to be the number of cores/threads that you can dedicate depending on how many you intend to run simultaneously.
https://linustechtips.com/topic/738586-help-with-the-psu/#findComment-9370547
Mostly we run only about two machines basicaly doing stuff between a normal windows and server stuff
https://linustechtips.com/topic/738586-help-with-the-psu/#findComment-9370675
And also i did not look that up that the 1060 did not have the plugs
Thanks for mentioning
https://linustechtips.com/topic/738586-help-with-the-psu/#findComment-9370678
