I have been planning my keycap setup for the better part of a few months now, and everything has gone to plan, except for the left shift. my original plan was to use a left tab sized key for it, until i realised that the left shift is a funny size that is inbetween a normal key and a tab key. Are there any cool custom keycaps out there that are made in this size? or a place i can buy one single in bright pink?
https://linustechtips.com/topic/738557-does-a-custom-iso-left-shift-exist/
1 minute ago, M.Yurizaki said:
According to https://deskthority.net/wiki/ANSI_vs_ISO and  http://www.wasdkeyboards.com/index.php/keycap-sizes, the ISO left shift is the same size as the left CTRL, or 1x1.25
Well, I can look at my keyboard right now and tell you that it is most definitely not the same size as my left ctrl xD
You can try to 3D print it
Quote or tag if you want me to answer! PM me if you are in a real hurry!
Why do Java developers wear glasses? Because they can't C#!
My Machines:
The Gaming Rig:
-Processor: i5 6600k @4.6GHz
-Graphics: GTX1060 6GB G1 Gaming
-RAM: 2x8GB HyperX DDR4 2133MHz
-Motherboard: Asus Z170-A
-Cooler: Corsair H100i
-PSU: EVGA 650W 80+bronze
-AOC 1080p ultrawide
My good old laptop:
Lenovo T430
-Processor: i7 3520M
-4GB DDR3 1600MHz
-Graphics: intel iGPU :(
-Not even 1080p
Then it's not an ISO keyboard now is it? :P
Figure out what the key size is supposed to be and buy the appropriate key cap. Most people follow the standard key cap sizing. If yours doesn't, your keyboard is dumb. >_>
2 minutes ago, fordaov3rlord said:
if i could afford a 3d printer then i wouldn't be worrying about this haha
Hahaha, true the good ones sure are expensive. If you live in the US you could try yo use a service like "print a thing" or "3D hubs"
My Machines:
The Gaming Rig:
My good old laptop:
Lenovo T430
-4GB DDR3 1600MHz
-Not even 1080p
If I lived in the US why would I have an ISO layout? xD
Do excuse my ignorance I don't know the "standard" layout names. I use the Latin American keyboard :/. On the flip side I can write "eñe" all day long :)
En este año el niño Iñigo Núñez engañó al noño Noreña con la piñata de antaño cuando Ñañingo Coruña encañonando al rebaño en la cañada, con saña, le enseñaba a cortar la caña.
My Machines:
The Gaming Rig:
My good old laptop:
Lenovo T430
-4GB DDR3 1600MHz
-Not even 1080p
basically, ISO is Europe/UK
