I have a MSI GT 730 , Which is having an issue with overheat I noticed that the fan is a bit loose so I tried to repair it by putting some grease and it work..
But right now I'm having an issue again with the GPU when it comes to Automatic Fan control
Regardless if I play games or just browsing the internet , the fan speed doesnt change causing it to overheat again..
I tried using MSI burner for the automatic Fan control and it worked ... But without MSI after burner the fan speed is stuck at 42% I already check the nvidia control panel
and the settings in automatic fan control is enabled..
What could be the problem ?
thank you guys in advance
https://linustechtips.com/topic/738350-gpu-fan-stuck-at-42/
Have you tryed deleating drivers and re installing them might be worth a shot and i would use afterburner all the time in the mean time
Specs:
CPU: Intel core i7 6700k (OC 4.6ghz)
CPU Cooler:Corsair H110i GTX
Motherboard: ASUS Z170 Deluxe
RAM: Kingston DDR4 HyperX Fury 16gb (2x 8gb) 2666MHz
GPU:EVGA GTX 980Ti Classified (OC)
Monitor: Acer predator x34, 3440x1440, 100hz
https://linustechtips.com/topic/738350-gpu-fan-stuck-at-42/#findComment-9367332
