4 minutes ago, mamamia88 said:
Long story short I have 20g so of mx-4 from a year or two maybe more ago. The cap is on so tight I need pliers to remove it every time I use it. Does it go bad?
It's usually a case of how it was stored and handled in the past, generally I'd recommend getting some more if you're not sure just because it's going on your processor after all, a few quid and a quick trip beats burning out components. That being said you can usually tell when you squeeze some out, if the bond is broken you might have some watery-like substance come out with the thermal paste which you can usually wipe off and re-apply some more, I'd hate to say you'd be fine just use your best judgement, it's not like food and will expire and has no best before date.
Sitting in a drawer full of screwdrivers
should be fine lol just squirt a little on a paper towel and see if any watery substance comes out, usually a little might build up closer to exit of the tube / syringe  but you should be fine :) Like I said if your worried about it just apply some for now and order a new tube
So, for something like that if it is well sealed and stored room temp climate controlled you can keep it 5 years and apply it without problem, it may last 4 years on the chip being good instead of the ideal 5 by the end of that time though. If you don't have it stored well it can go bad within a year.
That being said I'm also saying here that you SHOULD replace thermal paste on cpu's every 5 years due to deterioration during use load cases.
The Vinyl Decal guy.
Celestial-Uprising  A Work In-Progress
41 minutes ago, Rolling Potatoe said:
Should still be fine. I had a tube of mx2 that was 5+ years old, it was a bit stickier than usual, but fine all the same.
Need to see if I can dig up receipt on Newegg no idea when I actually bought it. Just been using it on systems I don't really care much about. In fact I used it yesterday while my hear was still dripping wet from shower in old 775 build. Not a good idea btw but the water seems to have missed the case. I hope I don't have to replace thermal paste on new build for along time because it's a pain in the ass to clean
