hello everyone,
I am in need of help as my computer just randomly did this and I have no idea what to do, my mouse nor keyboard works when on this screen and I have tried all sata ports and both my hard drives and they both have operating systems on them but it's not loading up :/ any ideas?
https://linustechtips.com/topic/738127-help-need-advice/
Try either of the hard drives on another computer, or try to choose a specific one from the boot options.
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
https://linustechtips.com/topic/738127-help-need-advice/#findComment-9364779
Thanks I will try them on a different computer, however I'm not able to get to the bios as I can't use my mouse or keyboard to click on the ok button in the picture and pressing any keys when starting up doesn't work either :/
https://linustechtips.com/topic/738127-help-need-advice/#findComment-9364799
10 minutes ago, loocre1 said:
hello everyone,
make sure the hard drives arent dead
https://linustechtips.com/topic/738127-help-need-advice/#findComment-9364822
1 minute ago, loocre1 said:
Thanks, I fairly sure they're not dead as I was using them however I turn my computer off and on again after it was working then this happened, could it be the motherboard?
i guess it could be. is you cpu heating up? if you have an air cooler you can see if the heatsink is heating up. to make sure the hard drives arent dead, see if they are vibrating when you turn the computer on. you can also burn a gparted onto a usb and see if the hard drives show up. Or if it doesnt boot with the usb in then it could be the motherboard. if that fails unplug your computer from the wall for 15 minutes. this should reset your bios and that may work. hope i helped!
https://linustechtips.com/topic/738127-help-need-advice/#findComment-9364879
Thankyou some much, very helpful :D one slight problem, it's coming up with this, could it be my ethernet adapter drivers?
https://linustechtips.com/topic/738127-help-need-advice/#findComment-9365303
Uninstall the drivers and reinstall them.
Main System: Phobos
https://linustechtips.com/topic/738127-help-need-advice/#findComment-9365447
