So I have a MSI GAMING X RX 470. The post looks messed up and games crash after a while. Even if I'm not gaming after a while screen goes black and recovers. This does not do it if I use my other cards just my rx 470. I did Not overclocked just what the settings are out of the box. Is there a way to fix or should I use my warranty.
https://linustechtips.com/topic/737687-problems/
This is clearly a GPU issue. You should go with the warranty and see how can they solve it or maybe REPLACE it at all. It is not caused by any drivers since it's when the PC posts for the first time. If it was when the windows was running and you were idling on the desktop, yeah, a driver could be faulty. But in this situation the GPU is the problem.
 || CPU: Intel i5-8600K || Cooler: CoolerMaster Hyper 212X || Motherboard: Gigabyte Z370 HD3P || GPU: Gigabyte GTX 1050ti OC Windforce 4GB || Memory: 16GB Crucial DDR4 3000mhz || HDD: WD Black 500GB + Seagate Barracuda 2TB || SSD: Samsung 980 1TB || PSU: Corsair VS550 || Case: nJoy Ice Cage || Fans: Segotep Halo Ring RGB ||Monitor: 2x Dell 27" P2717H IPS Full HD || Second Monitor/TV: LG 49UJ620V UHD || Mouse: Logitech G502 || Keyboard: Logitech G810 + Royal Kludge RK84 || Speakers: Philips SPA-5300 subw + Arylic 2.1 + DIY Bookshelves w/ Dayton Audio || Headphones: HyperX Cloud Flight S ||
TO BE UPGRADED:
>> Headphones << >> Keyboard << >> HDD << >> Mouse << >> PC Case << >> Memory(another stick) << >> Graphics Card <<
https://linustechtips.com/topic/737687-problems/#findComment-9360026
