Project Razor (Funding in progress)
Hello guys, I'm building a gaming RIG which costs $2000 total including monitor and peripherals. It'll be ready in 3 months and here are my choice of parts.
EDITED:
i5-3570k
MSI Z77A-GD65
DeepCool or Gamer Storm Assassin HSF
2 x 4GB Corsair Vengeance 1600Mhz
Samsung 840 Evo 120GB SSD
Seagate Barracuda 1TB Hard Disk
Sapphire R9 280X Vapor-X
Seasonic G series 550W PSU
Fractal Design Arc Midi R2
Peripherals:
ASUS VE248H monitor
Deck Hassium double shot PBT keyboard
Razer Deathadder 2013
https://linustechtips.com/topic/73768-project-razor-funding-in-progress/
Mostly because their warranty is terrible and if you ever have to speak to them and get something done, good luck.
I think that will not be a problem as the distro in my country has really good RMA and services. But I'll consider.
Never had any problems with my sapphire cards. And i got 2 year warranty at my store so when something happens i can just get my money back or get a replacement. No contact with Sapphire needed.
Edit: 600 watt will be enough for the build but if you want to upgrade in the future get the 650.
I dont know that CPU cooler. But I guess its fine. You dont need to buy the Wd black, its not worth it. Just get the blue or the seagate barracuda. And as you decided allready the Evo SSD. If that cpu cooler is expensive, grab the cooler master hyper 212. Have fun building
NZXT Phantom windowed, Asus Z77 Sabertooth, Intel 2600K, Noctua NH-D14, EVGA 780 Classified, Crucial Ballistic Tactical, Crucial M4 128GB + Samsung 850 EVO, Corsair RM850, Creative X-Fi Fatal1ty Peripherals: Sennheiser HD598, FinalMouse Classic, SteelSeries Qck Heavy, Ducky Shine Zero (MX Brown), AOC G2460PF & Qnix QX2710
Build Log: Phantom - Antique Noctua
I'm kinda in a dilemma again guys. After helping 2 people to build their PC, I kinda feel that the haswell is too expensive for its performance. You can't overclock it as well as the 3570k can. Also, the performance increase is insignificant. So I'm considering to hunt for clearance sales of Ivy Motherboard and a 3570k. I'll get a MSI Z77A-G45 instead.
I have to disagree, their service is quite nice, I never had an issue with them personally.
My sister did have an issue with her card, and Sapphire was a relief on the process.
Did you have a bad experience with Sapphire? Do you live in a country with Sapphire support (they have support centers across the map) ?
NO!!!!
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.1476958&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
Best deal there is.
Main Gaming PC - i9 10850k @ 5GHz - EVGA XC Ultra 2080ti with Heatkiller 4 - Asrock Z490 Taichi - Corsair H115i - 32GB GSkill Ripjaws V 3600 CL16 OC'd to 3733 - HX850i - Samsung NVME 256GB SSD - Samsung 3.2TB PCIe 8x Enterprise NVMe - Toshiba 3TB 7200RPM HD - Lian Li Air
Proxmox Server - i7 8700k @ 4.5Ghz - 32GB EVGA 3000 CL15 OC'd to 3200 - Asus Strix Z370-E Gaming - Oracle F80 800GB Enterprise SSD, LSI SAS running 3 4TB and 2 6TB (Both Raid Z0), Samsung 840Pro 120GB - Phanteks Enthoo Pro
Super Server - i9 7980Xe @ 4.5GHz - 64GB 3200MHz Cl16 - Asrock X299 Professional - Nvidia Telsa K20 -Sandisk 512GB Enterprise SATA SSD, 128GB Seagate SATA SSD, 1.5TB WD Green (Over 9 years of power on time) - Phanteks Enthoo Pro 2
Laptop - 2019 Macbook Pro 16" - i7 - 16GB - 512GB - 5500M 8GB - Thermal Pads and Graphite Tape modded
Smart Phones - iPhone X - 64GB, AT&T, iOS 13.3 iPhone 6 : 16gb, AT&T, iOS 12 iPhone 4 : 16gb, AT&T Go Phone, iOS 7.1.1 Jailbroken. iPhone 3G : 8gb, AT&T Go Phone, iOS 4.2.1 Jailbroken.
i5-4670k
Gigabyte Z87X-D3H
Corsair Neutron 120GB SSD
WD Black 1TB Hard Disk
Seasonic G series 650W PSU
Peripherals:
ASUS VE248H monitor
Wow this required funding...damn...
Ordered for a friend, but too bad that the mpower don't match my colour scheme...
You can change the color.... That other board is not even close to as good.
How about the GD55/65 instead?
Mpower is one of the best z77 boards. I say change your scheme or change its color.
I'd Stay away from "DeepCool or Gamer Storm Assassin HSF"
Get a Noctua cooler for tower HS. It's much better quality.
I recenetly change from a deep cool cooler to the NH-L12 and temps are Maxing out at 50 degrees (I have a locked CPU which I overclocked to 3.8) it used to reach 70 to 80.
Also get Samsung's evo or 840 pros for your SSD.
Also make sure your RAM will fit with your CPU Cooler. Clearance may be an issue.
Those ram kits are really tall.
CPU: i5 -2400 Cooler: Noctua NH-L12 Mobo: Fatal1ty Z68 Pro Gen3 Memory: Corsair Vengeance 8gb 1600mhz SSD: Samsung 840 120gb HDD: WD 3TB Green, Seagate Barracuda 1TB GPU: Asus GTX 760 Direct CU II (future SLI) Sound card: Xonar Phoebus PSU: Corsair RM series 750 watts Case: Aerocool Mechatron Fans: Bit Fenix Spectre Pros
Monitor:Samsung SyncMaster SA950, Philips Blade 234CLSpeakers: Logitech z506 Headset: Razer Tiamat 7.1 KB: Blackwidow Ultimate Stealth edition Mouse: Ouroburos Mouse pad: Golaithus Extended Speed edition Gamepad: Orbweaver Controllers: Wireless Xbox 360 Controller, Razer Hydra
System: Razer Edge Mouse: Razer Orochi Mouse pad: Razer Vespula Controlers: Razer Sabertooth (2 pcs.) Headset: Razer Blackshark Speakers: Razer Ferox What can I say, I'm a huge fan of Razer.  :D
WD Black is a waste of money really, it performs pretty much the same as the Seagate Barracuda 7200RPM drives.
If you're after reliability or something, you can go with a Constellation drive which is like the same price as the Black.
My Personal Rig - AMD 3970X | ASUS sTRX4-Pro | RTX 2080 Super | 64GB Corsair Vengeance Pro RGB DDR4 | CoolerMaster H500P Mesh
My Wife's Rig - AMD 3900X | MSI B450I Gaming | 5500 XT 4GB | 32GB Corsair Vengeance LPX DDR4-3200 | Silverstone SG13 White
