Posted February 13, 2017 Hi guys, thanks for your help in my earlier post. I've managed to round down a lot of options. Not sure how these compare - the main use will be to replace my PC motherboard sound card while maintaining portable use (phone/dap/console). I use low ohm headphones (16-32 range) such as the Senheisser Momentums. Thanks in advance! Link to comment https://linustechtips.com/topic/737494-ampdac-combo-for-pc/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 13, 2017 Topping is garbage, and Fiio isn't as far ahead as you might hope. Is there a reason you can't run your mid-fi lifestyle headphones straight from your devices? Link to comment https://linustechtips.com/topic/737494-ampdac-combo-for-pc/#findComment-9359079 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 13, 2017 Author 2 hours ago, SSL said: Topping is garbage, and Fiio isn't as far ahead as you might hope. Is there a reason you can't run your mid-fi lifestyle headphones straight from your devices? Hi, thanks for the response, my devices seem fine but not my PC. What would you recommend instead of the above? Link to comment https://linustechtips.com/topic/737494-ampdac-combo-for-pc/#findComment-9359762 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 13, 2017 1 minute ago, Jack Russel said: Hi, thanks for the response, my devices seem fine but not my PC. What would you recommend instead of the above? What's the matter with your PC? Link to comment https://linustechtips.com/topic/737494-ampdac-combo-for-pc/#findComment-9359765 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 13, 2017 Author 14 minutes ago, SSL said: What's the matter with your PC? My PC jack buzzes at times and sounds worse than on my devices. I'd say it sounds a bit muddy and the bass drops. I'm assuming that it is because I don't use a dedicated sound card (apparently the motherboard one is bad) but I am no expert at audio hardware. Link to comment https://linustechtips.com/topic/737494-ampdac-combo-for-pc/#findComment-9359806 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
