1. Budget & Location
I am Located in the United States. I am wanting a PC for at least 400$ and at most 500$.
2. Aim
I aim to have it play at 60+fps on high settings for games like CSGO, Dota 2, Rust, etc. My current laptop can run CSGO at 70fps so I have no doubt my current planned build will exceed that.
3. Monitors
1 monitor for now.
4. Peripherals
Covered
Current Build:
https://pcpartpicker.com/list/ZvvpNN
https://linustechtips.com/topic/737275-my-first-build-plan/
CPU: Intel Pentium G4560 3.5GHz Dual-Core Processor  ($61.99 @ Jet)
Motherboard: ASRock H110M-HDS Micro ATX LGA1151 Motherboard  ($46.99 @ SuperBiiz) find out if the bios supports kabylake.
Memory: Team Elite Plus 8GB (1 x 8GB) DDR4-2133 Memory  ($50.99 @ Newegg)
Storage: Hitachi Ultrastar 1TB 3.5" 7200RPM Internal Hard Drive  ($39.99 @ Amazon)
Video Card: PowerColor Radeon RX 480 8GB Red Devil Video Card  ($223.98 @ Newegg)
Case: Fractal Design Core 1100 MicroATX Mini Tower Case  ($29.99 @ SuperBiiz)
Power Supply: SeaSonic S12II 430W 80+ Bronze Certified ATX Power Supply  ($46.98 @ Newegg)
Total: $500.91
Generated by PCPartPicker 2017-02-12 21:22 EST-0500
https://linustechtips.com/topic/737275-my-first-build-plan/#findComment-9355529
Total: $500.91
I updated the current post with my current planned build. pretty similar. I might go with this one u gave me.
https://linustechtips.com/topic/737275-my-first-build-plan/#findComment-9355537
you're overspending on the mobo, ram and the 1050ti, and the psu isn't very good. get a cheap b250 or h110 mobo, team elite plus ram and an s12ii instead.
https://linustechtips.com/topic/737275-my-first-build-plan/#findComment-9355549
Also, do you think I could push the limit a little bit and be able to record my gameplay. or is it pusing it?
First find out what program you'll be using, and make sure it is stable. (Not a 20 day trial type of stuff) Cause if you want to do youtube, then most stable recorders are going to make your recording shit. And most good ones you're probably going to buy them.
CPU - i7-4790k
GPU - MSI 980 Ti
Mobo - MSI Z97 Gaming 5
Memory - 32 GB DDR3
Storage - 3.4 TB
Full List : https://pcpartpicker.com/list/sPgN8d
https://linustechtips.com/topic/737275-my-first-build-plan/#findComment-9355557
use amd relive to record, doesn't have much of an impact on performance.
https://linustechtips.com/topic/737275-my-first-build-plan/#findComment-9355559
Motherboard: Gigabyte GA-B250M-DS3H Micro ATX LGA1151 Motherboard  ($73.98 @ Newegg)
Memory: G.Skill NT Series 8GB (1 x 8GB) DDR4-2133 Memory  ($54.97 @ Jet)
Storage: Sandisk SSD PLUS 240GB 2.5" Solid State Drive  ($74.99 @ Adorama)
Video Card: Zotac GeForce GTX 1050 Ti 4GB Mini Video Card  ($138.99 @ SuperBiiz)
Case: BitFenix Nova ATX Mid Tower Case  ($28.99 @ NCIX US)
Power Supply: EVGA 430W 80+ Certified ATX Power Supply  ($33.88 @ OutletPC)
Total: $507.78
Generated by PCPartPicker 2017-02-12 21:31 EST-0500
ssd storage - yay
https://linustechtips.com/topic/737275-my-first-build-plan/#findComment-9355575
S12II 620W is pretty good, and it's $50 atm, pick that instead of the 450W S12II
idk
https://linustechtips.com/topic/737275-my-first-build-plan/#findComment-9355578
Total: $507.78
ssd storage - yay
best off to get a good rig now with a good GPU and buy an SSD later instead of compromising quality now
idk
https://linustechtips.com/topic/737275-my-first-build-plan/#findComment-9355586
used the 430w s12ii to keep the build in budget, and it's fine with up to a gtx 1070. but if he can spend a few bucks extra than go for it.
https://linustechtips.com/topic/737275-my-first-build-plan/#findComment-9355601
3 minutes ago, DYLHOODLEM said:
Which one do i pick now. lol. I get so confused, whoes build is better, ahhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh.
the other build compromises on performance quite alot and had a pretty mediocre psu. i'd recommend my build, make a 100-200gb boot partition and clone that to the ssd when you get it.
https://linustechtips.com/topic/737275-my-first-build-plan/#findComment-9355606
Very well my friend. thank you. You will see this build in action in a month or so.
https://linustechtips.com/topic/737275-my-first-build-plan/#findComment-9355635
Video Card: MSI Radeon RX 480 8GB ARMOR 8G OC Video Card  ($219.99 @ B&H)
Power Supply: SeaSonic S12II 620W 80+ Bronze Certified ATX Power Supply  ($49.99 @ B&H)
Total: $526.92
Generated by PCPartPicker 2017-02-12 21:43 EST-0500
$20 over budget, but you get a better PSU (higher wattage, same quality) and a motherboard that is updated to work with the new pentium whereas Hermann's was a maybe
idk
https://linustechtips.com/topic/737275-my-first-build-plan/#findComment-9355644
in a month? ask us again when you're getting the parts a week before, ryzen is arriving soon and it looks really good.
https://linustechtips.com/topic/737275-my-first-build-plan/#findComment-9355646
What is ryzen
AMD's new cpu lineup, no official reviews but rumours on price and performance looks pretty good.
https://linustechtips.com/topic/737275-my-first-build-plan/#findComment-9355660
