Radiators watt capacity
Go to solution Solved by 0ld_Chicken,
It's useless... Yeah a 120mm rad can dissipate 700w, but it'll require a VERY high DeltaT (difference between water and air temps).  the higher the DeltaT the more heat it can dump.  I've never seen manufacturer claims of watt dissipation that actually tell you what DeltaT they used to get those figures
http://hardwarelabs.com/blackice/sr2/240-mp/
How do they get the numbers for watt capacity?
Based on those numbers, so should I be able to replace my 2x 480mm with just a 240mm, but despite using EK Vardar F4-120ER at around 2000rpm (hits 2200 at 50C GPU) so do I doubt my 70C CPU and 45C-50C GPUs agrees (100% load over night temps).
Are those numbers meaningless or does other factors limits the cooling capacity in my system?
I speak my mind, sorry if thats a problem.
https://linustechtips.com/topic/736923-radiators-watt-capacity/
i'm fairly certain that the watt capacity means what watt your psu is though i could be wrong.
https://linustechtips.com/topic/736923-radiators-watt-capacity/#findComment-9351955
Its watts of heat that it can cool xCelsius or something along that line.
https://linustechtips.com/topic/736923-radiators-watt-capacity/#findComment-9352063
LTT Community Standards                                               Welcome!-A quick guide for new members to LTT
Man's Machine- i7-7700k@5.0GHz / Asus M8H / GTX 1080Ti / 4x4gb Gskill 3000 CL15  / Custom loop / 240gb Intel SSD / 3tb HDD / Corsair RM1000x / Dell S2716DG
The Lady's Rig- G3258@4.4GHz(1.39v) on Hyper 212 / Gigabyte GA-B85M / gtx750 / 8gb PNY xlr8 / 500gb seagate HDD / CS 450M / Asus PB277Q
https://linustechtips.com/topic/736923-radiators-watt-capacity/#findComment-9353642
I like the Black Ice line of radiators but I agree with OC, the wattage statement is theoretical.
Hit the Funny Button!    :D     The more you press it the funnier you get  :)
Projekt Wasserturm  Office/Game Room Remodel
https://linustechtips.com/topic/736923-radiators-watt-capacity/#findComment-9354198
