So I just got a used motherboard today. And my i5 2500k won't move from 1.5GHz no matter what, I have benchmarked and played games and nothing seems to work. I have a EVGA Z68 SLI. I have also tried playing with the voltage and overclocking. Any thing I can do to get rid of this 1.5GHz not budging?
lttstore.com
https://linustechtips.com/topic/736906-issue-with-base-clock/
What are you using to check clock speeds, have you checked your temps?
If temps are fine, it might be that a couple of the chokes are burnt out or the vrms are failing.
My rig:
CPU: i5 4690k 24/7 @4.4ghz (1.165v) Max 4.7ghz (1.325v) COOLER: NZXT Kraken X61 MOBO: Asus Z97-A   RAM: 16GB Crucial Ballistix Tactical   GPU: EVGA GTX 970 SSC   PSU: EVGA GS 650W   CASE: NZXT Phantom 530 HDD: WD Caviar Blue 1TB + WD Black 2TB
https://linustechtips.com/topic/736906-issue-with-base-clock/#findComment-9352592
My rig:
https://linustechtips.com/topic/736906-issue-with-base-clock/#findComment-9352596
