How hot is my pc?
1 hour ago, LoGiCalDrm said:Adjusting curve won't change anything in your room. But it will make GPU fans more effective. You can adjust curve with Afterburner or similar software.
17 hours ago, xDylanio said:Well the exhaust fans were making my room enormously hot. So I thought it had to do something with my pc, and could you teach me to how to do a fan curve?
Completely agree with LoGiCalDrm. The heat getting out is awesome, you don't want it in the PC. But using Afterburner, you can create a custom profile, that way fans get faster earlier. Even at max gaming, my MSI R9 380 Gaming doesn't even get close to 60 degrees, but I also have my fans kick on at full speed super early. Otherwise, most recent GPU's all have later fan curves to save on noise. I'd rather have noise than heat, but that's just me.
Simple video:
