Hello!
I am in the animation / entertainment industry and need some help- I am a first time builder, will be buying everything new, and building from scratch:
Budget & Location: $7,000 USD (although it would be great to come in under budget:) ) / Los Angeles
Aim: I will be using this for work, so daily use will be mostly Photoshop, with some Maya modeling / animation, with occasional rendering and sound editing / compositing / video editing. Here is a rough estimate of use:
  • Photoshop: %60
  • Maya: %30
  • Zbrush: %10
  • After Effects: %2.5
  • Camtasia: %2.5
Monitors: Wacom Cintiiq 27HD (Wacom pen used daily), and a 4K Dell 3216Q.
Peripherals (already owned)
  • Epson V600 scanner
  • Epson P600 printer
  • Fujitsu Scan Snap scanner
  • 27”HD Wacom Cintiq
  • Secondary Dell 3216Q 4K Monitor
  • TP Link Archer T9E wifi card
  • Corded mouse / keyboard
  • I plan on running Windows 10 (not purchased yet)
Why are you upgrading? I currently only have a laptop, and have been saving up for a long time to build the right system so I can work from home.
Case Preference Ideally, it would be nice to have the option to plug in my headphones on the top of the monitor. It would also be cool to have a side window.
HD setup I would like a fast system, and have heard great things about M.2, unless you guys have any other suggestions. I was thinking I would have 4 HDs:
  • M.2 250GB for OS
  • M.2 500GB for software
  • M.2 250GB for Photoshop scratch disk
  • 2 to 4 TB spinning drive for data
I am not sure if this HD setup is best / recommended, or even possible, just my initial thoughts after watching a ton of Linus's videos.
Conclusion
I would like to buy and build soon, I don't have a heard deadline. I am open to any and all suggestions. Thank you in advance, I appreciate your time, experience, and help.
https://linustechtips.com/topic/735303-first-build-please-help/
btw you cant have 3 m.2 in one build so i recommend either a 1 tb ssd or 2 500gb ssds
https://pcpartpicker.com/list/dJLXFd
meets requirements, 2 1080s should be enough for 4k stuff too and rendering.  Btw 2 1080 are better than 1 titan xp, and if you want xps, just get 2 in sli.  I think you should get 2 1080s because i wouldn't want to custom make a watercooled titan xp if i were you.
edit: you can change the hdd if you want to to 2 4tb drives.
https://linustechtips.com/topic/735303-first-build-please-help/#findComment-9335178
17 minutes ago, Newb1234 said:
Hello!
  • Photoshop: %60
  • Maya: %30
  • Zbrush: %10
  • Camtasia: %2.5
  • M.2 250GB for OS
Conclusion
https://pcpartpicker.com/list/wBKVCy
under budget and gave you plenty of storage
Current Rig=  AMD Ryzen 9 5900x, Asus Crosshair Hero VIII, EVGA RTX 3070 FTW3 ultra, 32gb Corsair Vengence Pro RGB 3000hz White, EVGA 750 P2 PSU, 1TB Samsung 980 Pro, 500gb samsung 860 evo, 250GB Samsung 850 evo, 2TB Samsung 970 Evo Plus, 2TB seagate firecuda sshd,  LianLi PC 011 Dynamic XL ROG edition, Corsair h150i elite capelix
https://linustechtips.com/topic/735303-first-build-please-help/#findComment-9335187
Thats pretty good except even in a full tower case, I'd recommend watercooled gpus so they operate at about the same speeds, cause in sli one of the gpus will be smothered from breathing.  Also i dont think op need 64 gb of ram but why not :)
https://linustechtips.com/topic/735303-first-build-please-help/#findComment-9335200
CPU: Intel Core i7-6950X 3.0GHz 10-Core Processor  ($1579.99 @ SuperBiiz)
CPU Cooler: NZXT Kraken X61 106.1 CFM Liquid CPU Cooler  ($119.99 @ B&H)
Motherboard: ASRock X99 Taichi ATX LGA2011-3 Motherboard  ($209.99 @ Newegg)
Memory: Corsair Vengeance LED 64GB (4 x 16GB) DDR4-3200 Memory  ($424.99 @ Best Buy)
Storage: Samsung 960 Evo 250GB M.2-2280 Solid State Drive  ($129.99 @ B&H)
Storage: Samsung 850 EVO-Series 500GB 2.5" Solid State Drive  ($159.99 @ B&H)
Storage: Toshiba X300 5TB 3.5" 7200RPM Internal Hard Drive  ($149.99 @ B&H)
Video Card: EVGA GeForce GTX 1080 8GB FTW Gaming ACX 3.0 Video Card (2-Way SLI)  ($599.89 @ B&H)
Case: Phanteks ECLIPSE P400 ATX Mid Tower Case  ($74.99 @ Newegg)
Power Supply: EVGA SuperNOVA G2 850W 80+ Gold Certified Fully-Modular ATX Power Supply  ($116.98 @ OutletPC)
Operating System: Microsoft Windows 10 Pro OEM 64-bit  ($129.77 @ OutletPC)
Total: $4296.45
Generated by PCPartPicker 2017-02-08 20:38 EST-0500
My Daily Driver:
Acer Predator Helios 300
»« Intel Core i5-8300H »« 16GB DDR4 RAM »« NVIDIA GeForce GTX 1060 6 GB »« Silicon Power A60 512 GB M.2 SSD »«
Toshiba PC L200 1 TB HDD »« Microsoft Windows 10 Home »«
https://linustechtips.com/topic/735303-first-build-please-help/#findComment-9335266
Total: $4296.45
1. go watercooled on the gpus
2. even though op says 3 different ssd drives, a 1tb 850 evo ssd would suffice
https://linustechtips.com/topic/735303-first-build-please-help/#findComment-9335313
Tell that to OP, not me. :P
My Daily Driver:
https://linustechtips.com/topic/735303-first-build-please-help/#findComment-9335317
https://uk.pcpartpicker.com/list/yGy2TH
u need to add case and yr storage setup to this and maybe change the mb coz i cba to look to see if it has a gpu temp header ngl :D
the psu is more then needed but full modular and will last on gpu upgrades and so ok
you could also change so a titan xp if you wanted
international racing driver
My Build
i5-7600k
hyper x fury 16gb (2133)mhz
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
agon 1440p 144hz tn monitor
corsair strafe mx silent KB
corsair void rbg (wired)
razer mamba te with firefly mouse pat
ps4 controller using ds4 windows
https://linustechtips.com/topic/735303-first-build-please-help/#findComment-9335320
Hey hconverse02, xdeathshot20, CatXice, and Freezanator, thank you all for your time and the quick responses!
After reviewing your builds, I had a few questions,
  • I am curious as why two 1080s are better than say, the Quadro M4000, which is what is recommended by Nvidia to run Maya?
  • Not sure if the suggestions here of dual GPU cards has anything to do with having two monitors? But if so, I am willing to not use the 4K monitor and just stick to only using the Wacom full time if that will make things better / faster / more stable? @ hconverse02, are you saying you recommend water cooling for these GPUs?
  • Why only 1 M.2 drive? Is it possible to go more than 1? If so, how would you allocate them? (i.e. 1 drive to OS and the other to software?) Also, would the suggestion of 1TB SSD in leui of multiple Hds slow me down since i'd like to allocate 1 drive to a Photoshop scratch disk / dedicated OS drive, dedicated app drive?
@ hconverse02: Do Titan cards require a water cooler? I though they could run without water cooling?
@ hconverse02, xdeathshot20, CatXice, I was wondering why you recommend the i7 6900 over the i7 6950X Freezanator recommended?
Thanks again for your time- and please forgive my noob questions :)
https://linustechtips.com/topic/735303-first-build-please-help/#findComment-9335338
Yeah op would probably want 2 1080s and a 1000w psu for those
https://linustechtips.com/topic/735303-first-build-please-help/#findComment-9335347
even with 2 1080s u would only needa 700w psu so i would go for 750 or 800 just so its not on its limt all the time
My Build
i5-7600k
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
https://linustechtips.com/topic/735303-first-build-please-help/#findComment-9335355
So titan xps are blower style coolers, but one of the fans might be choked off in sli (if you use 2 titan xps) and the same goes with 1080s, but there is a watercooling option from evga.  Someone else would need to check me on this but 2 1080s outperform a quadro by a lot because the 1080 is meant for gaming and rendering work (idk what a quadro is for)
https://linustechtips.com/topic/735303-first-build-please-help/#findComment-9335377
Eh 900w would be safe, especially with 2 gpus, a 6900k or 6950k or 6800k, and plenty of ram to go around
https://linustechtips.com/topic/735303-first-build-please-help/#findComment-9335380
part picker says with 2 1080 694w of power
My Build
i5-7600k
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
https://linustechtips.com/topic/735303-first-build-please-help/#findComment-9335387
yeah just the 1080s
no thats the full system
My Build
i5-7600k
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
https://linustechtips.com/topic/735303-first-build-please-help/#findComment-9335391
My Build
i5-7600k
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
https://linustechtips.com/topic/735303-first-build-please-help/#findComment-9335401
*freaks out* Thats on the verge of the psu.  Theres no hurt in going 900w right? Its only like £70 more
50w under and its 80+ gold rated this psu cud handle like 800w if it had to and y spend money when u dont have to
My Build
i5-7600k
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
https://linustechtips.com/topic/735303-first-build-please-help/#findComment-9335416
Whatever floats your boat
manufactures make the psu with some buffer for 1 and if they rate it to 750 with 80+ gold and yr running under 750 its fine if u started to push 800w on it then ye it will not like it and will not last long but if it goes over 750 for short times it will handle it no problem people freak out to much about psu power limts
My Build
i5-7600k
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
https://linustechtips.com/topic/735303-first-build-please-help/#findComment-9335437
