Extra fan for 212 evo
Solved by scottyseng,
13 hours ago, mlg_terrible said:Anyone know where i can get an extra fan i can attack for a 212 evo? Or how i could attach another one?
Any regular 120mm fan will work. The Hyper 212 Evo has a second set of fan brackets in the box that you use to attach the second fan.
As for what fan to buy, that depends on your preference of performance vs noise. For example, I have two delta fans on my 212+ and it works really good...at scaring the dog away.
