These are pictures of some ECC memory I acquired recently. It says 16 GB kit, which I assume means 2x8.
However one one of the sticks there is another sticker that was covered up.
I know that its 2x8, however they both have different memory speeds. The server I am looking at buying only supports the PC3-10600 that the Pacific Sun sticker says, not the Microns PC3-12800. They are ECC, and that is new to me.
https://linustechtips.com/topic/734734-ecc-memory-speed-help/
3 minutes ago, Electronics Wizardy said:
what server is this going in?
Speed should be fine, faster memory will work and just be clocked slower.
It will most likely be an HP ProLiant DL380 G6 8-Port. Im buying it used for about $100 USD, without ram or HDD. It comes with 2X Xeon 5650's hex core. This will be my first server build, and I know they can be tricky to match parts with.
https://linustechtips.com/topic/734734-ecc-memory-speed-help/#findComment-9328312
that will work fine then.
https://linustechtips.com/topic/734734-ecc-memory-speed-help/#findComment-9328316
