Hello guys, my name is Mark and I live in Italy, I'm 43 and I love modding pc
I want to present my 4th project in the field modding.
This new mod is just on building a Wall Mount, but that will not be fixed to the wall.
I leave for now the imagination, a big screen  40"
Material for the realization*
Wood - imitation leather - screws varies - glue.
Special thanks to Bitspower, and Vincent and LiHan Mayhems and Mod-One, Asrock, thank you immensely for support,
Special thanks to Danilo Lettieri  for his creations cnc
Motherboard:  Asrock Z270 Taichi
Cpu: i7 6700K
Ram:    Corsair Dominator Platinum 4X8Gb DDR4
Vga: EVGA GTX 1070 Founders Edition
Ssd:   Corsair Neutron Series XT 480Gb
Cable:  Mod-One Cable
Wb Cpu:   Bitspower CPU Block Summit EF (Intel) (Acrylic Top Version)
Wb Vga:   Bitspower Nvidia GTX 1080 Reference Acrylic V1
Wb Hd:   Bitspower S350 Acrylic Top With Clear Panel
Pump:   Alphacool VPP655 - single edition
Top D5:  Bitspower Dual D5 MOD TOP (Acrylic Version)
Reseivor:  Bitspower Water Tank Hexagon - Acrylic (Limited Edition)
Tubing:   Bitspower None Chamfer PETG Link Tube OD14MM-Length 500MM
Fittings:   Bitspower Black Sparkle Fitting
Liquid:    Mayhems
Radiator:   Bitspower Leviathan Xtreme 360 4xG1/4" Radiator
Render*
CPU - i7 6700K @ 4.0ghz  Motherboard - Asrock Z270 Taichi   Ram - 32GB Platinium Dominator  GPU - Evga 1070 GTX   Storage - Corsair Neutron Serier XT 480GB,  WD 4 TB Enterprise    PSU - Corsair HX 850i
https://linustechtips.com/topic/734627-project-hexagon/
In before "Build Logs should have some build progress - moved to planning" :D
Nice idea though, any ideas on GPU etc yet ?
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/734627-project-hexagon/#findComment-9327346
Let's start with a gem just made to  CNC from Danilo Lettieri
https://linustechtips.com/topic/734627-project-hexagon/#findComment-9327387
Then finally after a long journey, It came the first material by Bitspower  :D
https://linustechtips.com/topic/734627-project-hexagon/#findComment-9327393
Some pictures of Bitspower material. :x
https://linustechtips.com/topic/734627-project-hexagon/#findComment-9338586
Start building the big pedestal, wood then hold up the entire mod.   ;)
https://linustechtips.com/topic/734627-project-hexagon/#findComment-9349180
Continuous with the step of gluing and screwing, the pedestal.   :D  :D
https://linustechtips.com/topic/734627-project-hexagon/#findComment-9352115
  • 2 weeks later...
Continuous modification of the pedestal, slightly shortening the legs, and smoothing out all the angles, and adding other safety screws. ;)
Then start with the central panel. :D
https://linustechtips.com/topic/734627-project-hexagon/#findComment-9399523
That afternoon I decided to begin to place the trays department, folding and cutting the rigid pipes. :P
https://linustechtips.com/topic/734627-project-hexagon/#findComment-9399525
Here we are after a week of fever. :D  :D
I started this afternoon to cut the parts I had traced.
https://linustechtips.com/topic/734627-project-hexagon/#findComment-9401499
Here we are with a new step.  :D
I adjusted and fixed at the rear of the 5 reservoir, set the pumps and made holes for the bulkhead, and bend the upper tubes of the radiator, with the use of the templates of Bitspower.
Stay tune .....  :D
https://linustechtips.com/topic/734627-project-hexagon/#findComment-9424583
This morning I went to finally withdraw the faux leather fabric   :D
He was missing the adhesive to glue it. ;)
https://linustechtips.com/topic/734627-project-hexagon/#findComment-9433359
Thanks to Mayhems Solutions, for sending me their fantastic liquid. ;)
https://linustechtips.com/topic/734627-project-hexagon/#findComment-9463370
Before and after the first pass of epoxy resin spray, to harden around the panel, before pasting the skin. ;)
https://linustechtips.com/topic/734627-project-hexagon/#findComment-9470900
I begin the step of bonding the fabric, with plenty of white glue, in several steps .....  :D  :D
https://linustechtips.com/topic/734627-project-hexagon/#findComment-9487354
And after a few days of drying glue you begin to reassemble everything.....  xD
And in the meantime came the new girl: Asrock Z270 Taichi
https://linustechtips.com/topic/734627-project-hexagon/#findComment-9522357
  • 1 month later...
Meanwhile after some problem with the expedition and the customs that had lost the parcel, what I needed to do was continue to continue Mod. 9_9
https://linustechtips.com/topic/734627-project-hexagon/#findComment-9796720
  • 2 weeks later...
Meanwhile after some trouble with the customs, the Waterblock of Bitspower, and this afternoon came the new video card from Amazon.   :D
Ready to fit all fill the plant, and finish Mod.
https://linustechtips.com/topic/734627-project-hexagon/#findComment-9847182
5 hours ago, mrchow19910319 said:
why not go with a 1080Ti?
the water block is a 1080 design, i think the PCB layout on the cards is the same although i may be wrong
****SORRY FOR MY ENGLISH IT'S REALLY TERRIBLE*****
Been married to my wife for 3 years now! Yay!
https://linustechtips.com/topic/734627-project-hexagon/#findComment-9848786
