So soon i am going to do a HUGE upgrade on my PC, what i want to do is get a Zotac 1070 AMP Extreme and put it in a H440, and i want to get a new liquid cooler but i am not sure which one, i have my eyes on a but i dont know if this is the best choice, if it is where should i put the liquid cooler, i have heard that it is the best to put it on the front of the case.
 https://www.amazon.co.uk/gp/product/B01M191GRY/ref=ox_sc_act_title_4?ie=UTF8&psc=1&smid=A3P5ROKL5A1OLE
My current RIG
https://uk.pcpartpicker.com/list/YB2B4C
Thanks in advance
PC Specs: Motherboard: MSI Tomahawk X570  CPU: Ryzen 5900X  CPU Cooler: NZXT 240 mm Kraken Series AIO     GPU: Asus Strix ROG 1080 TI OC Edition    PSU: Corsair RM850 850W   Storage: 2 X 4TB, 2 X 1TB HDD And 1 X 1tb m.2 samsung 980 pro Case:  NZXT H440 2015 Edition
https://linustechtips.com/topic/734051-liquid-cooler/
My current RIG
Thanks in advance
Image result for nzxt kraken x62
https://linustechtips.com/topic/734051-liquid-cooler/#findComment-9321101
If you want something from the best, then EK Predator 360 or Kraken x62 or Corsair's H115i.
HAL9000: AMD Ryzen 9 3900x | Noctua NH-D15 chromax.black | 32 GB Corsair Vengeance LPX DDR4 3200 MHz | Asus X570 Prime Pro | ASUS TUF 3080 Ti | 1 TB Samsung 970 Evo Plus + 1 TB Crucial MX500 + 6 TB WD RED | Corsair HX1000 | be quiet Pure Base 500DX | LG 34UM95 34" 3440x1440
Hydrogen server: Intel i3-10100 | Cryorig M9i | 64 GB Crucial Ballistix 3200MHz DDR4 | Gigabyte B560M-DS3H | 33 TB of storage | Fractal Design Define R5 | unRAID 6.9.2
Carbon server: Fujitsu PRIMERGY RX100 S7p | Xeon E3-1230 v2 | 16 GB DDR3 ECC | 60 GB Corsair SSD & 250 GB Samsung 850 Pro | Intel i340-T4 | ESXi 6.5.1
Big Mac cluster: 2x Raspberry Pi 2 Model B | 1x Raspberry Pi 3 Model B | 2x Raspberry Pi 3 Model B+
https://linustechtips.com/topic/734051-liquid-cooler/#findComment-9321169
i am not planning to get a "K" cpu but if you could recommend me one that can run on this motherboard then i will consider because im not sure what processor i should get.
thanks
https://linustechtips.com/topic/734051-liquid-cooler/#findComment-9321876
thanks
The reason I mentioned the 'K' cpu is because they are unlocked for overclocking, but you would need a suitable motherboard i.e One with a Z97 chipset.
To be honest it wouldn't be worth swapping the i7 4790 for the i7 4790K as it would be very minimal gain. You also don't need a £120 cooler for your current cpu either as you can't overclock.
I would just do the case/gpu upgrade and maybe a new psu as that Aerocool isn't great. Kitguru have a review of the 600W model in the link below.
http://www.kitguru.net/components/power-supplies/zardon/aerocool-integrator-600-watt-psu-review/
https://linustechtips.com/topic/734051-liquid-cooler/#findComment-9323297
