apparently, no. you can try the gammaxx 400 which performs better or the cryorig m9i which performs the same for less instead, they seem to fit fine.
https://pcpartpicker.com/list/WbJnnn
2 minutes ago, Ottens238 said:
No the SPEC-ALPHA not the SPEC-02
well according to:
http://www.ebuyer.com/750989-corsair-carbide-series-spec-alpha-mid-tower-gaming-case-white-red-cc-9011083-ww?mkwid=s_dc&pcrid=51482418059&pkw=&pmt=&gclid=Cj0KEQiA2uDEBRDxurOO77Cp-7kBEiQAOUgKVyo5oQNK-z5nKru0Nlea3-Annuj30196sSZA1Ta0rP4aApn38P8HAQ
http://www.coolermaster.com/cooling/cpu-air-cooler/hyper-212-evo/
it technically shouldn't fit but I've got a 212 evo in a case that it shouldn't of been able to fit in so i can't say for sure...
3 minutes ago, Ottens238 said:
besides the psu looking really scary, you'll need to get a different case if you want to keep the 212 since it likely wouldn't fit. you can try as sometimes it might still fit(my TPC 812 was a few mm past my case's limitation but it still fit) but do it at your own risk.
Is this psu better?
https://pcpartpicker.com/user/ottens238/saved/#view=nFJpgs
3 hours ago, Ottens238 said:
Does the cooler master hyper 212 evo fit in the corsair spec-alpha?
156MM is the max height for a CPU cooler in that case, so no.
11 hours ago, Ottens238 said:
better. you already bought the rig?
