Need help choosing fans for my build
5 hours ago, PrincipalFlash said:Okay. So 2x140 in the front and 1x140 aer in the back for exhaust. Why no top fans? What fans would you recommend for the intake then?
The idea was that your X62 in the front is intaking, the 1x140 in the rear is exhausting. If you meant 3 AER fans in addition to the 2 stock fans included with the X62 then you could do as follows (depending on which size of AER you want), mostly for aesthetic reasons:
3x120 AER in the top exhausting
2x140 AER in the top exhausting + 1x140 AER in the rear exhausting.
Both of these configurations would be with the X62 intaking at the front. Its worth noting that without significantly slowed down exhaust fans you're likely going to be running with some negative pressure in your system (which isn't horrible, just less ideal for dust build up). You could combat this by using some of your 140mm stock case fans and set up a push/pull on your front intake rad to increase overall intake airflow (which will also reduce your CPU temps).
the reason I had not originally suggested top case fans is because they aren't really needed, and because your fan count dictated they should be used elsewhere.
