https://pcpartpicker.com/list/GXhw8K
I have everything connected except for the GPU. The computer turned on, all the LEDS lit and fans spinning. I turned it off and uplugged the power. Unboxed the 1070 and installed like I have in all of my other builds. I connected the VGA power and screwed it in place. As soon as I plugged the main power in, a red LED lit on the GPU by the power cables. I tryed turning it on, but the power button created no reaction.
Right now its just the CPU, RAM, PSU, and Motherboard. Everything else is detected. I have reseated the cables many times. Pressing the power button creates no reaction. Im concerned somthing is dead. I do not have a mobo speaker to listen to error codes.
Computers r fun
https://linustechtips.com/topic/733746-no-power-after-gpu/
you psu doesnt give enough power sorry, my mistake, i though that you had 550w one
Remember to quote me (or someone else), otherwise we won't going to recieve your answers...
PC Specs                   PCPartpicker full performance builds (from350$-1250$)
https://linustechtips.com/topic/733746-no-power-after-gpu/#findComment-9318131
red means not enough power delivery. you need that little light white
https://linustechtips.com/topic/733746-no-power-after-gpu/#findComment-9318141
15 hours ago, LabRat said:
you have all 16 wires plugged into the card?
I waited a few minutes and it turned on again. I re-connected everything and it worked. I think the cables came loose from the back of the PSU.
Computers r fun
https://linustechtips.com/topic/733746-no-power-after-gpu/#findComment-9320885
