Not enough power?
Go to solution Solved by Ezkamoz.,
14 minutes ago, Emma Nieuwenhuis said:
Just in case, what would happen if it wasn't enough?
If it wasn't enough it would just shut off
I have an EVGA 500w PSU with 40a on the 12v rail. I want to use a 980ti. Can I run the card? I have an i3 6100 (Don't lecture me about bottlenecks) and my only drive is an M.2 SSD. And if I don't have enough power, what would happen if I tried to use one? Would my computer refuse to turn on, would it run slower, would I break something?
https://linustechtips.com/topic/733213-not-enough-power/
The EVGA 500W is not a very good PSU. Check out the PSU tier list in my signature and get something tier 2 or 1 if you're using a 980ti which is power hungry and hot.
https://linustechtips.com/topic/733213-not-enough-power/#findComment-9312617
Well, it isn't terrible, though I haven't given it near its full load. Let's just say that I have a 980ti and I have my current system. I want to use the 980ti, but I don't have the money at the moment to get a new power supply. Is there any help you can give me with my current situation?
https://linustechtips.com/topic/733213-not-enough-power/#findComment-9312627
Well, it sort of is. The ripple suppression on those is very, very bad and they're 30 USD for a reason. If you're going to put a GPU in there that cost $600 new you can stretch to get a $70 PSU that won't struggle to power a 980ti. This Deepcool is a decent PSU and should power your 980ti and is as cheap as I'd go for your GPU.
http://pcpartpicker.com/product/Mp2rxr/deepcool-power-supply-dq550st
https://linustechtips.com/topic/733213-not-enough-power/#findComment-9312661
