i have a problems with my computer. here are the spec of my computer:
- core i3 3240 3.4ghz
- 2x4 gb of RAM
- intel dh61ww motherboard
- Nvidia GT220 1gb ddr3 graphic card
- 120gb samsung 750 evo ssd + 500gb seagate hdd
- deepcool gammax 400 + 120mm pwm fan
- 5 case fans @120mm
- simbadda 380w power supply
The problems are :
- when first time i start the power button, it start normal and log on to windows for about 5 minutes and then died
- after that i try to start it again, and nothing happen. the cpu fan, case fans and power supply fan didn't work. only motherboard led indicator turn on
- i feel the power supply went down, so i jump-up the 24 pin cable with paperclip and the power supply fan start to spin. after that i put two of my case fans again (still in jump-up condition) and its spin. from here i knew that power supply still running
- then i took off the graphic card and plug the monitor cable to onboard graphic.then my computer start again....it works
My Question :
1. Is possible that pcie x16 slot in motherboard broken? i.e power shorcut
2. did my power supply 380w (not even 80+) enough? or should i replace it with the new one?
3. If the pcie x16 broken because of power shortcut, should if effect the other component? or should i buy another motherboard?
thank you
https://linustechtips.com/topic/732884-what-is-wrong-with-my-pc/
- 2x4 gb of RAM
The problems are :
My Question :
thank you
That's a very sketchy PSU, I feel like it's dead or dying. Get a new one.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/732884-what-is-wrong-with-my-pc/#findComment-9309971
2 minutes ago, Rade18 said:
but i still want to revive it...hehe
but I need to know if it has a external power because it could be the psu if it does. and its not a load problem because even 80+ would be enough cause the system would only pull 200ish watts at full load.
https://linustechtips.com/topic/732884-what-is-wrong-with-my-pc/#findComment-9310000
2 minutes ago, MatrixGrenade said:
Well since the pc works without the gpu I would say that maybe the gpu died. Does your gt 220 have an extra psu connector on it, like a molex or 6 pin?
Is it the GPU? well about that i need to test it to my friend computer this afternoon. My gt 220 doesn't need an extra power fromm psu
https://linustechtips.com/topic/732884-what-is-wrong-with-my-pc/#findComment-9310003
then its probably a dead card. and i wouldnt recommend putting it in another pc cause if i'm right it may damage your friends pc.
https://linustechtips.com/topic/732884-what-is-wrong-with-my-pc/#findComment-9310018
1 minute ago, TheRandomness said:
You have a much higher chance of living by just buying a new one.
-Thread moved to Troubleshooting.
Indeed,...that could be great to have a new one......
I just need to configure where is the problems are....:)
https://linustechtips.com/topic/732884-what-is-wrong-with-my-pc/#findComment-9310024
great suggestion, i shouldn't do that.....
getting a new GPU then.....any recommend?
https://linustechtips.com/topic/732884-what-is-wrong-with-my-pc/#findComment-9310040
4 minutes ago, Thread212 said:
What do u mean died? is it completely shutdown or just wont display anything?
If its shutdown and wont turn itself on automatically usually its just get overheated.
Check the CPU/GPU temperature.
And for God sake change your psu, seasonic s12ii is the best budget psu out there afaik.
yeah its shutdown.....after  a while i try to start it again, but it won't start
about the psu i already change it to FSP some well brand here in indonesia...thanks anyway
https://linustechtips.com/topic/732884-what-is-wrong-with-my-pc/#findComment-9310065
3 minutes ago, MatrixGrenade said:
budget? 200-250 rx480. 300+ gtx 1070 or 1080(if possible) or you try to bake your gpu like linus.:D
wow ...that to expensive....you know that in indonesia for electronic is very expensive....
is rx480 doing good enough with i3 3240?
hehe but thanks anyway
https://linustechtips.com/topic/732884-what-is-wrong-with-my-pc/#findComment-9310081
Oh woops, I forgot what cpu you had. Either an Rx460 or a gtx 1050. Cause if u ever do upgrade your pc you will have gpu you can put in it, and it will pair somewhat well with the cpu.
https://linustechtips.com/topic/732884-what-is-wrong-with-my-pc/#findComment-9310094
wow...that's good choice then....thanks MatrixGrenade
https://linustechtips.com/topic/732884-what-is-wrong-with-my-pc/#findComment-9310106
