My friend gave me his evga gtx 980 ACX 2.0 because he was upgrading to the 1080. I have an MSI gtx 980 4g. I was told they would be sli compatible so I decided to take the plunge and watercool my first pc. After putting on both water blocks and installing them I noticed that the MSI is a lot bigger than the EVGA (Width). Are these cards not compatible after all and if so what can I use for the sli bridge? I have to order more fittings from bitspower as I was counting on just a straight shot between the two cards.
Any information/help is appreciated. Thanks guys!
https://linustechtips.com/topic/732710-sli-watercooling-problem/
Only way to fix the bridge issue is with a flexible connector I think.
Main PC CPU: 7700K, MOBO: Asus Strix, GPU: Aorus Extreme 3080, PSU: EVGA Supernova G2 750, RAM: Corsair Vengeance 16GB Storage: 970 Evo 1tb
Lounge PC CPU: 4790K MOBO: Asus Hero VII GPU: EVGA 3060 Ti PSU: Corsair RM650 RAM: Kingston HyperX 16gb Storage: 970 Evo 1TB
https://linustechtips.com/topic/732710-sli-watercooling-problem/#findComment-9308208
use the sli bridge that came with your board, theyre usually flexible
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/732710-sli-watercooling-problem/#findComment-9308211
They will be compatible, though both your sli bridge and your watercooling connector between both card will need to be angled. You will have a better chance at achieving this with 45 degree fittings and flexible tubing, and with a flexible sli bridge
Record holder for Firestrike, Firestrike Extreme and Firestrike Ultra for his hardware
Top 67 for TimeSpy and Top 26 for Timespy Extreme
Intel i7 10700 || 64GB Kingston Predator RGB || Asus H470i Strix || MSI RX 6700XT Merc X2 OC || Corsair MP600 500GB ||  WD Blue SN550 1TB || 2TB Samsung QVO || EVGA 550 GM || EK-Classic 115X aRGB CPU block - Corsair XR5 240mm RAD - Alphacool GPU Block - DarkSide 240mm external rad || Lian Li Q58 || 2x Cooler Master ARGB 120MM + 2x Noctua  Redux 1700RPM 120MM  || Terramaster D4-320 HDD enclosure w/ 1x 8TB 256mb cache 7200rpm Ironwolf & 1x 4tb WD Red 256mb cache 7200rpm
https://linustechtips.com/topic/732710-sli-watercooling-problem/#findComment-9308275
Compression fittings for hard tubing and flexible tubing are different.
CPU: Ryzen 1600X @ 4.15ghz  MB: ASUS Crosshair VI Mem: 32GB GSkill TridenZ 3200
GPU: 1080 FTW PSU: EVGA SuperNova 1000P2 / EVGA SuperNova 750P2  SSD: 512GB Samsung 950 PRO
HD: 2 x 1TB WD Black in RAID 0  Cooling: Custom cooling loop on CPU and GPU  OS: Windows 10
https://linustechtips.com/topic/732710-sli-watercooling-problem/#findComment-9308365
Anything works with g1/4. Just need the appropriate fitting and hose.
https://linustechtips.com/topic/732710-sli-watercooling-problem/#findComment-9309988
