Im running a Gigabyte 990fxa ud3 mobo currently, I was running windows 8 which didnt require anything to be installed, but on windows 7 i had to to use the CD to install the lan driver. Now im having the problem on windows 8.1 where there is an unidentified network/limited ethernet. I have searched all over Gigabytes site and I have found NOTHING related to windows 8.1 but there brand new boards or something, Is there anything I can do to fix this or find a solution?
Thanks!
https://linustechtips.com/topic/73249-no-drivers-for-81-lan/
I have the 970A UD3 and I don't need any drivers for my LAN to work.
[AMD Athlon 64 Mobile 4000+ Socket 754 | Gigabyte GA-K8NS Pro nForce3 | OCZ 2GB DDR PC3200 | Sapphire HD 3850 512MB AGP | 850 Evo | Seasonic 430W | Win XP/10]
https://linustechtips.com/topic/73249-no-drivers-for-81-lan/#findComment-1003628
apparently I do, any suggestions then? because everything was fine on windows 8
I would try uninstalling the network drivers via Device Manager and download the latest lan driver from Gigabyte's website: http://download.gigabyte.us/FileList/Driver/mb_driver_lan_realtek_8111_w8.exe
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/73249-no-drivers-for-81-lan/#findComment-1003890
Uninstall the drivers for the LAN from the Device Manager, then click on it and choose the option to update automatically from web. Windows 8/8.1 don't need dedicated drivers for the LAN, Wireless, etc..., because of that there are not much drivers for these operating systems on the manufacturers websites.
You can always use a Wireless stick so that you can update the operating system and it will download the drivers automatically.
CPU: AMD Ryzen 9 - 3900x @ 4.4GHz with a Custom Loop | MBO: ASUS Crosshair VI Extreme | RAM: 4x4GB Apacer 2666MHz overclocked to 3933MHz with OCZ Reaper HPC Heatsinks | GPU: PowerColor Red Devil 6900XT | SSDs: Intel 660P 512GB SSD and Intel 660P 1TB SSD | HDD: 2x WD Black 6TB and Seagate Backup Plus 8TB External Drive | PSU: Corsair RM1000i | Case: Cooler Master C700P Black Edition | Build Log: here
https://linustechtips.com/topic/73249-no-drivers-for-81-lan/#findComment-1006140
