HDD Power Trouble?
Go to solution Solved by JenjerBread,
this diagram might help
is this a 3.5" hdd
I edit my messages often. Please refresh for the latest message.
I am not always on the same thread. Tag or Quote me to get my attention.
Remember to Mark the solution to help others in the future.
SFF
CPU: R7 5800x3D
Motherboard: Asus ROG Strix x570-i
RAM: Corsair vengeance 64GB 3200MHz CL16
Cooler: Asetek 645LT
GPU: EVGA GTX 1080Ti Black
Case: Dan Case A4
Storage: 2TB Sabrent (PCI-E 3.0) - Windows
Storage: 1TB Crucial P5 Plus (PCIE 4.0) - Fedora
Storage: 1TB Samsung 860 EVO (SATA) - Steam
https://linustechtips.com/topic/732406-hdd-power-trouble/#findComment-9304573
if it is then you'll need 12 volts aswell
SFF
CPU: R7 5800x3D
Case: Dan Case A4
https://linustechtips.com/topic/732406-hdd-power-trouble/#findComment-9304576
if its 2.5" like in laptop hdd size then 5v will be fine
SFF
CPU: R7 5800x3D
Case: Dan Case A4
https://linustechtips.com/topic/732406-hdd-power-trouble/#findComment-9304580
you smoked the cable or the hdd??
SFF
CPU: R7 5800x3D
Case: Dan Case A4
https://linustechtips.com/topic/732406-hdd-power-trouble/#findComment-9304589
you'll need a molex pinout diagram connect ground to black 12v to yellow...
5v to red and ground to black cable next to it
SFF
CPU: R7 5800x3D
Case: Dan Case A4
https://linustechtips.com/topic/732406-hdd-power-trouble/#findComment-9304602
SFF
CPU: R7 5800x3D
Case: Dan Case A4
https://linustechtips.com/topic/732406-hdd-power-trouble/#findComment-9304619
SFF
CPU: R7 5800x3D
Case: Dan Case A4
https://linustechtips.com/topic/732406-hdd-power-trouble/#findComment-9304622
no worries
i made a custom sata connection like this
SFF
CPU: R7 5800x3D
Case: Dan Case A4
https://linustechtips.com/topic/732406-hdd-power-trouble/#findComment-9304629
