4 hours ago, Captain Chaos said:
I use to swear by this stuff. But the cure time isn't worth it by todays standards. MX4 works just as good without the '200 hours' of cure time that artic silver 5 recommends.
I7-7700k@5.1ghz + 1080ti @ 2050mhz + 32gbs Ram + 2TB SSD = CSGO
i7-6700k@4.9ghz + 980ti @ 1501mhz + 16gbs Ram + 1 TB SSD = Backup
i7-3770k@4.8ghz + 680 4gb + 32gbs Ram + 500gb SSD = Retired/Office work
https://linustechtips.com/topic/732233-thermal-compound/#findComment-9303774
Cure time?  Never noticed anything like that, I always just put it on the CPU, put the cooler on top and start using the PC (or hand it over to the owner).  Zero issues so far.
Gonna look into that though, tnx for pointing it out.
https://linustechtips.com/topic/732233-thermal-compound/#findComment-9304064
Build
Mobo: MSI B550 MAG Tomahawk  ||||| Ram: 32 GB GSkill Trident Z RGB ||||| CPU: Ryzen 5800X ||||| GPU: ASUS RTX 3080 TUF OC ||||| Mouse: Logitech G502 ||||| Headset: Sony WH1000XM3 ||||| Keyboard: Logitech G810 Orion Spectrum ||||| Monitors: Acer XG270HU & LG UltraGear 34GP83A-B ||||| AudioStuff: ONKYO DAC HA200 / Audio Techinca ath-ad900x / MXL TEMPO KR USB Condenser Microphone ||||| Storage: 4 TB WD Black --- 2 TB WD Red --- Toshiba 258 GB M.2  ||||| Custom Loop -  Radiators: 3x360 Rad ||||| Case: LianLi O11d XL Black ||||| PSU: Seasonic X series GOLD 1250w
Laptop: Dell XPS 15 9570 4k With a Logitech MX Master
https://linustechtips.com/topic/732233-thermal-compound/#findComment-9304269
