Custom Cable lengths?
On 2/1/2017 at 8:05 PM, KSP said:Hi guys,
So I am in the process of ordering some custom sleeved cables for my build (first time ordering custom cables). It is inside the Phanteks Enthoo Evolv ATX TG. It has a standard ATX motherboard and 1 ASUS Strix GTX 1080 in it. The power supply is the EVGA Supernova P2. I am getting a little confused when it comes to lengths for the build. I WAS originally just looking of the lengths of CableMod's cable lengths, but they seemed to long in my opinion. Here are the lengths from CableMod that I have currently in for my cables:
- 1 x 24 Pin ATX Cable (600mm)
- 2 x 4+4 Pin EPS Cable (700mm)
- 2 x 6+2/6 Pin PCI-e Cable (750mm)
- 4 x 6+2 Pin PCI-e Cable (600mm)
- 1 x Quad SATA Power Cable (850mm)
- 1 x Quad SATA Power Cable (700mm)
- 2 x Dual SATA Power Cable (500mm)
- 1 x Triple 4-Pin Molex Cable (750mm)
- 1 x Dual 4-Pin Molex Cable (500mm)
- (Literally just copied and pasted)
Any changes/input is appreciated. Thank you. (Sorry if this is a dumb question, but I really don't want to have to deal with extra cable management to do especially since the case has glass on both sides lol)
Hey @KSP - This is my personal rig, using the same case you mentioned, and GPU you mentioned. I am using standard lengths in my personal rig, I hope this helps. ![]()
