Would you like to trade 1.5 cm (from 16.5 to 18 cm) in width in a small form factor case to be able to put a 2.5 slot card in it?
3 members have voted
  1. 1. Would you like to trade 1.5 cm (from 16.5 to 18 cm) in width in a small form factor case to be able to put a 2.5 slot card in it?
    • yes
    • no
      3
Hi guys
I'm designing a  case, and i'm on the final stage with it. Today I asked myself about the possibility to put a 2.5 slot card in a small form factor case, as almost noone can fit one. Would it be a deal breaker for you? to have the width of the case enlarged of 1.5 cm ( from 16.5 to 18 cm)? Is it for you a good feature the fact that you can install an oversized gpu? The case would also become 1-1.5 cm shorter ( i would change the internal placement of some stuff).
I would love to hear your feedback
https://linustechtips.com/topic/731947-tradeoff-with-small-form-factor-pc/
