So, i have 2 Benq xl2411z, and my videocard has only one DVI-Dl-port, so i bought a DP port male to DVI-DL male cable, but the monitor from the the displayport out doesnt run on 144hz(the second monitor) and i don't understand why.
The cable i bought are https://smile.amazon.com/gp/product/B00H8CBW78/ref=od_aui_detailpages00?ie=UTF8&psc=1  pleasae help.
https://linustechtips.com/topic/731894-confused-about-cables/
See here, under "Connecting to a 120+ Hz monitor":
https://linustechtips.com/main/topic/729232-guide-to-display-cables-adapters-v20/
https://linustechtips.com/topic/731894-confused-about-cables/#findComment-9298420
On 2/1/2017 at 10:37 AM, Sank said:
my cable is displayport to dvi-dl
As noted in the guide, DisplayPort to DVI passive cables/adapters are equivalent to Single-Link DVI only.
https://linustechtips.com/topic/731894-confused-about-cables/#findComment-9306249
