I've got an old lga 775 mobo and i have used a new 700w psu with it and it won't post. It does post with my old 300w one (last time I checked) so, why doesn't it post? I'm thinking maybe the molex connector on the new one wasn't meant to be on the mobo? Can someone help?
https://linustechtips.com/topic/731399-my-computer-won%C2%B4t-post/
Is there a switch on the PSU anywhere? try flipping that.
"You think your Commodore 64 is really neato! What kind of chip you got in there a Dorito?" -Weird Al Yankovic, All about the pentiums
PC 1(Lenovo S400 laptop):
CPU: i3-3217u
SSD: 120gb Super Cache mSATA SSD
HDD: Random seagate 5400rpm 500gb HDD
RAM: 8GB Crucial DDR3-SODIMM
OS: Windows 10 education
PC 2(2014 Mac Mini):
CPU: i5-4260u
HDD: 5400rpm 500gb
RAM: 4gb DDR3 (soldered on :( )
OS: MacOS Sierra/Windows 10 pro via bootcamp
If there's no post it's either Mobo or PSU. Either could be dead, or one of the connectors might be unplugged. Since your mobo was working, I'd check connections, then if still no post it means your new PSU is DOA.
What's your new power supply? Just curious.
REMILIA Mk.IIIG CPU: Ryzen 7 5700X3D, Cooler: Gelid Sirocco (Arctic MX6), RAM: 4x 8Gb sticks of Patriot Viper Steel Series 3600 CL17, Mobo: AsRock X570 Taichi, GPU: Inno3D RTX 3080 iChill x4 10G, Storage: 1TB Intel 670p NVME SSD boot drive, a few 1TB and 512gb SATA/NVME SSDs for game storage, 6 hard drives:2-12 TB, PSU: Montech Century II 850W, Case: Silverstone FLP02, PCIE Cards: Cheap Chinese Marvell 88SE9215 4 port SATA card, Sonnet Allegro USB3.2 Card Monitors: ViewSonic Elite XG270QC (165hz, 1ms MPRT, 1440p, VA, Freesync PP, pneumatic stand), electriq 27qhd180i (IPS, 180hz, 1440p, 1Ms), iiyama G2530HSU-B (75Hz, Freesync, one in landscape, one in Portrait, all on pneumatic monitor stands).
Mic: iSK UPM-1 USB XLR interface with Neewer NW700, Audio: Sabaj A3 160W DAC/AMP + Wharfdale Diamond 220 + Mission MS6 Sub, Fiio K11 R2R DAC + Douk P5 (Toshiba Tubes), Sendy Peacock, Mouse: Glorious Model I, Keyboard: Glorious GMMK ISO with Mengmoda MMD Tactile (main) and Kailh Box Navy (Function keys), Tribosys 3203 brush lubed, Taihao Green forest caps.
It's from a Spanish brand called Tacens (yes, I am Spanish). They're a reliable brand. I'll check again with the 300w one and make sure It's not the mobo. Thanks.
1 minute ago, Noofen said:
I'm dumb, but not that dumb ;)
I'm not saying that you are dumb. PSU switches are easy to miss. I looked up your PSU (Nice PSU BTW) and there is one. Make sure it is set to I. If it is or that doesn't work, try another wall cable. Maybe the cable doesn't work.
CPU: i3-3217u
CPU: i5-4260u
HDD: 5400rpm 500gb
Of course I already flipped the switch, but thanks anyway haha. I'll try another cable too, thats a good idea.
If you have another desktop lying around you can also try it on that one too. There is a chance you got a defective one. It happens all the time. You can send it back and get a new one. Whatever you do though, DO NOT TAKE IT APART. The internals of a PSU can kill you and if it comes to that, send it back and get another. It isn't worth dying.
CPU: i3-3217u
CPU: i5-4260u
HDD: 5400rpm 500gb
Ok, I'll try that, thanks
