I have no idea what is the problem. I already have try many things to work on it. I get 99% usage of GPU at 40C-45C during load. My CPU usage around 50%-60% at 60C. Or maybe this is because of GPU failure?  Thank you
Game that i've tried:
Dota Low Setting: 50-60fps
CSGO: High - 60fps
Rocket league medium - 24fps
PC Spec:
Processor: I5 4460
Mobo: Gigabyte H81M-DS2
GPU: GTX 760 Windforce 4gb
RAM: 8GB DDR3
Monitor: BenQ G900W (1440x900)
PSU: CM B500 v2
Storage: 1TB WD. 1TB Seagate
https://linustechtips.com/topic/731151-gpu-usage-99-low-fps/
13 minutes ago, Izzuddin Saidin said:
if it's not software
Check your hard drive with crystal disk info, might be causing the slow down
otherwise possibly the motherboard, but I'm betting it's the hard drive, how old are they?
https://linustechtips.com/topic/731151-gpu-usage-99-low-fps/#findComment-9290464
Its the hard drive can cause that problem?
The WD one about 1 and half year but seagate 3 years ++.
I install all game at seagate HDD
https://linustechtips.com/topic/731151-gpu-usage-99-low-fps/#findComment-9290473
well take it out and try a game on just the other hard drive
If I remember right Joker has a hard drive lower his fps here
https://linustechtips.com/topic/731151-gpu-usage-99-low-fps/#findComment-9290516
@Streetguru
I trying using my laptop ssd (Kingston 240GB) on my pc.
But the result still the same. what should I check?
Or maybe the GPU is not working properly?
Also I have run the online benchmaker at http://oortonline.gl/ and my total score is 5970.
It is good or bad?
https://linustechtips.com/topic/731151-gpu-usage-99-low-fps/#findComment-9294169
15 minutes ago, Izzuddin Saidin said:
If your fps didn't improve and you've tried reinstalling windows it's maybe the GPU ya, if you have a spare GPU you could check the motherboard, doubtful that's the issue though, or possibly the PSU, probably not the issue again though
On the bright side RX 470s are cheap and highly effective
https://linustechtips.com/topic/731151-gpu-usage-99-low-fps/#findComment-9294257
Just now I just found that the GPU clock stuck at 135Mhz. What should I do?
Also the power consumption at average 195% TDP (idle)
https://linustechtips.com/topic/731151-gpu-usage-99-low-fps/#findComment-9295728
Sounds like that GPU is just borked
luckily there's an RX 480 on sale for $175
https://www.newegg.com/Product/Product.aspx?Item=N82E16814137049&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-PCPartPicker, LLC-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
https://linustechtips.com/topic/731151-gpu-usage-99-low-fps/#findComment-9296227
