At my mothers house (she lives in the country) she always has horrible internet but actually worse than what she pays for how do I make her internet go to the max?
MY MAIN BUILD AT FATHERS HOUSE!
CPU: AMD FX-8300 3.3GHz 8-Core Processor CPU COOLER:  Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler
Motherboard: Gigabyte GA-970A-DS3P ATX AM3+ Motherboard
RAM: 32gb ddr3
Hard Drive:  Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
Graphics Card:  MSI Radeon RX 470 DirectX 12 Radeon RX 470 ARMOR 4G OC 4GB 256-Bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card
Case: Rosewill TYRFING ATX Mid Tower Case
Network Adapter:  TP-Link TL-WN781ND PCI-Express x1 802.11b/g/n Wi-Fi Adapter
Case Fans:  Corsair Air Series AF140 Quiet Edition 67.8 CFM 140mm Fan (PLUS THE STOCK CASE FAN)
Monitor:  Asus VG248QE 24.0" 1920x1080 144Hz Monitor
Keyboard:  Thermaltake CHALLENGER PRIME Wired Gaming Keyboard
Mouse:  MSI Interceptor DS B1 Wired Optical Mouse
Speakers: Logitech Z200 0W 2ch Speakers
https://linustechtips.com/topic/730939-wifi-issues/
It's probably something you would have to contact the ISP about. I doubt you can do anything from your end
https://linustechtips.com/topic/730939-wifi-issues/#findComment-9287890
2 minutes ago, Verrierr said:
Why is it titled wi-fi issues? are you using Wi-fi to connect to her modem?
Her routers the issue
RAM: 32gb ddr3
https://linustechtips.com/topic/730939-wifi-issues/#findComment-9287910
Wi-fi speed or internet speed? Is the wireless bad, or the internet connection bad?
qυoтe мe pleaѕe!
Me at the Apple store: "So how fast is this little macbook?"
Apple employee: "Cheetah Fast. Lightning Fast. It's Really, really, fast."
https://linustechtips.com/topic/730939-wifi-issues/#findComment-9287914
Internet connection
RAM: 32gb ddr3
https://linustechtips.com/topic/730939-wifi-issues/#findComment-9287921
5 minutes ago, Jiaweeeee said:
Get better routers
Go nearer to the router
Switch to 5.0ghz channel
What's a cheap but really good router? (gotta buy her something And this is all I got since she's been complaining)
RAM: 32gb ddr3
https://linustechtips.com/topic/730939-wifi-issues/#findComment-9287929
1 minute ago, Lilninjsways said:
Internet connection
You need to get in touch with her ISP and get them to have a look. I had a problem for a while and they had to change out my old modem.
qυoтe мe pleaѕe!
https://linustechtips.com/topic/730939-wifi-issues/#findComment-9287931
Budget?
qυoтe мe pleaѕe!
https://linustechtips.com/topic/730939-wifi-issues/#findComment-9287938
3 minutes ago, Natsoup said:
Budget?
100-150 usd
RAM: 32gb ddr3
https://linustechtips.com/topic/730939-wifi-issues/#findComment-9287951
5 minutes ago, Natsoup said:
Budget?
100-150
RAM: 32gb ddr3
https://linustechtips.com/topic/730939-wifi-issues/#findComment-9287959
2 minutes ago, Jiaweeeee said:
For that price , ASUS RT-N66U Dual-Band Wireless-N900 Gigabit Router is within your budget
Nice thank you
RAM: 32gb ddr3
https://linustechtips.com/topic/730939-wifi-issues/#findComment-9287987
qυoтe мe pleaѕe!
https://linustechtips.com/topic/730939-wifi-issues/#findComment-9288096
