not sure if i broke the cpu speed or the bios, but apparently my i7 6700k is running at 0.8ghz  but everything is the same as it was befor it got broke somehow running at 4.6/4.7
im just a bit confuzzled on whats going on, and no i have not done any changes since about a month ago or so, and everything that does a hardware poll reads the cpu as running at 0.8ghz
https://linustechtips.com/topic/730820-i-broke-cpu-speed/
Speedstep? it's lowering the clock when the CPU is not in demand?
PC - NZXT H510 Elite, Ryzen 5600, 16GB DDR3200 2x8GB, EVGA 3070 FTW3 Ultra, Asus VG278HQ 165hz,
Mac - 1.4ghz i5, 4GB DDR3 1600mhz, Intel HD 5000.  x2
Endlessly wishing for a BBQ in space.
https://linustechtips.com/topic/730820-i-broke-cpu-speed/#findComment-9286605
Is the computer performing normally in games and benchmarks? If it's behaving as if the CPU is actually at 800mhz I'd reset the CMOS and start over regarding your OC, once you know the system is back to normal.
https://linustechtips.com/topic/730820-i-broke-cpu-speed/#findComment-9286619
Reset the CMOS so you BIOS goes back to complete stock :D
3 minutes ago, star_weaver said:
task manager, logitech arx, even cpu-z is showing it at 0.8
cinebench is also reading it at 0.8 as apposed to 4.0
doesnt move over that under load
That cinebench score isn't even that bad for a 6700K...
Looking at my signature are we now? Well too bad there's nothing here...
What? As I said, there seriously is nothing here :)
https://linustechtips.com/topic/730820-i-broke-cpu-speed/#findComment-9286660
