Trouble With Bootable USB
Go to solution Solved by piemadd,
56 minutes ago, ShadowTechXTS said:
Which computer exactly? Try Rufus to burn the ISO to the USB.
34 minutes ago, Space2867 said:
You could try using a different USB drive and using UNetbootin to burn the ISO. I recently had the exact same issue and doing both of these solved the problem.
Thanks Guys!  It works! turns out it was a bad image
I have been going at this for 2 hours now, not even thinking about LTT. I am trying to install Kali Linux and when i try to put it onto a usb disk it is all fine. The computer that im trying to but it on recognizes it in bios, but doesnt boot to it. I have been using PowerISO for this. Should i use anything different? I haave tried both usb 2.0 and 3.0 in their respective ports.
i like trains 🙂
https://linustechtips.com/topic/730591-trouble-with-bootable-usb/
i like linux
il try
also congrats on 123 posts. that is very magical
i like trains 🙂
1 minute ago, Implosivetech said:
wat about the .txt.sha1sum file?
You couldd scan the file with a sum reader and then compare it with the txt file to see if it is the correct file. You can do this with this utility.
Please Quote or tag me @GigabitXe to make sure I see your reply.
im trying ur method first. i have my hopes up for it.
i like trains 🙂
i like trains 🙂
