Laptop not charging
Solved by ProjectBox153,
16 minutes ago, crazysteve240 said:Well, it is a 4-cell battery and it only lasts around 30 minutes on battery alone. I think it is around 4-5 years old, I'm not sure.
You could be having an issue with that. My old, recently-retired daily driver laptop did this sometimes. It was a Toshiba Satellite Pro C650. I'd recommend getting a new battery for the laptop.
