4 minutes ago, stanmarsh19 said:
when i try to stream gta v on windows 10 with obs. it lags like crazy ive tried to turn it down to 1080p 30 or even 720 30. it keeps on lagging
Try running NVIDIA NVENC as the encoder. I use it like that and it really helps the stream and recordings.
CPU: Intel Core i7 8700
GPU: Gigabyte GeForce GTX 1070
MOBO: ASUS Z370-F STRIX
RAM: 16GB Corsair Vengeance DDR4 2133MHz
https://linustechtips.com/topic/730357-obs-stream-lag/#findComment-9281552
