Hi! I am doing a rather budget-oriented build, where I am trying to get a i5-6500 and a gtx 1060 in it. For my build, I was planning of
CPU - i5-6500 (2.7 jt)
GPU - Galax GTX 1060 3gb (3 jt)
Mobo - AsRock H81M-HDS (0.8 jt)
Memory - G.Skill ripjaw PC14900F3-14900CL10S 1x8gb ddr3 (0.9 jt)
Storage - Samsung 850 evo 250 gb (1.5 jt)
PSU - Seasonic ECO 430 (0.7 jt)
OS - Win-10 home (1.4 jt)
All of this adds up to approximately 11.8 million IDR, which is around 892 USD. I don't have a case, a monitor, and keyboard, and It's already much more expensive that I anticipated for. Where can I cheap out on this build so I can add a 1080p monitor, a strafe keyboard, and a random case? I can cheap out on the GPU and CPU but I would like to keep an i5, and if possible, a 1050 or above. Also, the case, monitor, and keyboard will add up to 5.5 million IDR, so I really want it to be much cheaper than this. Thanks!
https://linustechtips.com/topic/730327-pc-help/
30 minutes ago, Wumkin said:
What country are you from?
Indonesia, hence IDR.  And OP,  are there any pc repair shops around you?  They could have some used things that aren't always that bad.
Corsair 4000D RGB
Asus B550 Tuf Gaming II
Asus 7700XT Tuf Gaming
AMD 5600x3d
32gb 3200mhz gskil
https://linustechtips.com/topic/730327-pc-help/#findComment-9281353
