I'm soon buying parts for this pc, but I'm a reasonable amount over budget.
PCPartPicker part list: https://uk.pcpartpicker.com/list/9BCxWX
Price breakdown by merchant: https://uk.pcpartpicker.com/list/9BCxWX/by_merchant/
CPU: Intel Core i5-6400 2.7GHz Quad-Core Processor  (£165.00 @ Aria PC)
Motherboard: Gigabyte GA-H110M-H Micro ATX LGA1151 Motherboard  (£39.98 @ Amazon UK)
Memory: Patriot Signature Line 8GB (1 x 8GB) DDR4-2133 Memory  (£46.11 @ Amazon UK)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (£44.05 @ Amazon UK)
Video Card: XFX Radeon RX 480 4GB RS Video Card  (£184.26 @ More Computers)
Case: Zalman ZM-T4 MicroATX Mini Tower Case  (£19.15 @ Amazon UK)
Power Supply: SeaSonic 450W 80+ Gold Certified ATX Power Supply  (£68.80 @ Alza)
Total: £567.35
Generated by PCPartPicker 2017-01-29 11:00 GMT+0000
I'd prefer to spend under £550 as a limit, and £500 is optimal. Short of deals or sales, what are some other ways to cut costs without impacting the performance too much, or the reliability (that's why I went SeaSonic). I guess I could buy used, but I'd prefer not to as this is my first build and I'm relatively new, so I want to have the warranty, and security of new parts. How could I cut cost?
https://linustechtips.com/topic/730257-cutting-cost-help/
Power Supply: Super Flower Golden Green HX 450W 80+ Gold Certified ATX Power Supply  (£55.95 @ CCL Computers)
Total: £554.50
Generated by PCPartPicker 2017-01-29 11:08 GMT+0000
Super Flower make very, very good PSUs. The GGHX is as good as that Seasonic unit but 450w, you can upgrade to a 550 if you want.
idk
https://linustechtips.com/topic/730257-cutting-cost-help/#findComment-9280776
Storage: Seagate BarraCuda 1TB 3.5" 7200RPM Internal Hard Drive  (£35.94 @ Aria PC)
Case: Thermaltake Versa H23  ATX Mid Tower Case  (£26.48 @ Aria PC)
Power Supply: Corsair CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  (£47.99 @ Ebuyer)
Total: £545.76
Generated by PCPartPicker 2017-01-29 11:14 GMT+0000
https://linustechtips.com/topic/730257-cutting-cost-help/#findComment-9280788
Total: £554.50
OK. I just hadn't heard of them so I wasn't too sure, the name sounded relatively suspicious but I'll go with them. Any other ideas for cutting cost??
https://linustechtips.com/topic/730257-cutting-cost-help/#findComment-9280791
Total: £545.76
I'm pretty sure that's a tier 3 or 4 PSU on most lists, which was why I was avoiding it.
https://linustechtips.com/topic/730257-cutting-cost-help/#findComment-9280794
1 minute ago, Ethan Meskin said:
OK. I just hadn't heard of them so I wasn't too sure, the name sounded relatively suspicious. Any other ideas?
That's because they're an ODM (original design manufacturer) - they make PSUs that are rebranded by other manufacturers and sold.
Doesn't really matter - it's not like after Tier 3 you see lots of gains. I power my system with a 520W Tier-3 Seasonic unit. That unit you suggested was Tier 4, so the CXM is good. I'd say the CXM since the Zalman case sucks ass
idk
https://linustechtips.com/topic/730257-cutting-cost-help/#findComment-9280796
That CXM is tier 3, it's a pretty good unit.
http://www.tomshardware.com/reviews/corsair-cx650m-psu,4770.html
https://linustechtips.com/topic/730257-cutting-cost-help/#findComment-9280800
The case I want is the source 210 or the 1100 but it was the cheapest so??
https://linustechtips.com/topic/730257-cutting-cost-help/#findComment-9280805
Can try thermaltake's versa cases, seems pretty good for a few pounds more.
https://linustechtips.com/topic/730257-cutting-cost-help/#findComment-9280841
OK. Would buying used RAM be an issue, I could also do it with the CPU and that would take the total down to like 490, so I could either stick with my stuff or get a better PSU/GPU/motherboard if I got what I want. Basically I might only have 500, but 550 is about how much I might get in a optimal scenario, so if I only got 500 I'd get this PC but if I got more I could upgrade some stuff? Should I buy that stuff used?
https://linustechtips.com/topic/730257-cutting-cost-help/#findComment-9280857
shouldn't have an issue, especially if the lifetime warranty is still active. used parts can be at a pretty good deal sometimes, i'd say try to find a used haswell i5/i7/xeon or x79+E5 2660-2670 cpu and mobo if it's cheap enough.
https://linustechtips.com/topic/730257-cutting-cost-help/#findComment-9280935
I would get the exact same CPU, but for £40 less. I would still need to buy a cooler tho bcus the stock wasn't included? Cheap non overclocking cooler recommendations?
https://linustechtips.com/topic/730257-cutting-cost-help/#findComment-9281006
you'll need a cpu cooler no matter what, but on a non-k i5 any random cooler should suffice.
https://uk.pcpartpicker.com/product/3jTmP6/arctic-cooling-cpu-cooler-ucacoap11301bua01 something like this or even a cheapo used stock cooler for less.
https://linustechtips.com/topic/730257-cutting-cost-help/#findComment-9281027
will i then have to buy thermal paste? i was just going to use the stock cooler so i haven't researched this stuff?
https://linustechtips.com/topic/730257-cutting-cost-help/#findComment-9281053
most cpu coolers will come with thermal paste so don't worry about it. that cooler has some already applied on it.
https://linustechtips.com/topic/730257-cutting-cost-help/#findComment-9281061
good, thanks. Will there be any worries with used cpu/ram? i'm buying from https://uk.webuy.com/search/index.php?stext=i5+&section=&refinecat=Intel+Processors&CategoryID=911,  which gives 2 year warranty so?? I dont know?
https://linustechtips.com/topic/730257-cutting-cost-help/#findComment-9281073
you'll be fine, the cpu very rarely fails even with overclocking.
https://linustechtips.com/topic/730257-cutting-cost-help/#findComment-9281077
