I have a corsair h100 mounted on the top of my case, with stock fans. ITS LOUD!
I would like to change out the fans with silent 120mm ones ( two of them) any ideas? I want to make sure they will fit back on the radiator and inside
case: corsair carbide air 540 motherboard: asus maximus V formula assassin  cpu: intel i7 3770k 3.5ghz cooling: corsair h100  psu: corsair gold ax750w  gpu: amd radeon 7950 3gb  ram: 8gb g.skill sniper  drives: 120gb Samsung 840 ssd, 2tb western digital black
https://linustechtips.com/topic/730016-silent-fan-question/
AFAIK any fans that will fit on the radiator and in the case will work.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/730016-silent-fan-question/#findComment-9277916
Silent Wings 3
https://linustechtips.com/topic/730016-silent-fan-question/#findComment-9277935
a 120mm fan is a 120mm fan, they are generally all the same thickness. but have you tried adjusting the fan speed, I know on my H100iV2 I was able to use the corsair link software to turn the fan speed as low as possible and set the pump to "performance" (as quiet was actually noisier) and my OPEN AIR system is inaudible.
thing to remember is even the quietest fans will be noisy if they are running fast.
https://linustechtips.com/topic/730016-silent-fan-question/#findComment-9278034
know ill have to check
https://linustechtips.com/topic/730016-silent-fan-question/#findComment-9278046
What speed are your running your fans at? Have you tried lowering them?
https://linustechtips.com/topic/730016-silent-fan-question/#findComment-9280338
