I have planned a pretty nice mini itx build and i wonder if everything will work nice together (bottlenecks etc.) my main consern is power supply while it is only 860w, but if you know any bigger 160mm psu let me know;)
case: bitfenix prodigy
mb: asus p8z77-i deluxe (what is the difference between wd and non wd???)
cpu: intel 3770k
ram: corsair dominator platinum 1866mhz 2x8gb
psu: corsair ax 860i
cooling: corsair h100i
1tb hdd and kingston hyperx 240gb ssd
and to top it all of one of the asus ARES II
https://linustechtips.com/topic/7299-extreme-ares-2-mini-build/
Just going to out this out there; you can't run a dual GPU setup in the Prodigy or any mini ITX board as there is only one PCI slot. You won't be able to fit that lot in their either with a 240mm radiator and 2 120mm radiators.
So back to the drawing board; did you want the craziness of basically quad 7970's or a mini ITX form factor?
https://linustechtips.com/topic/7299-extreme-ares-2-mini-build/#findComment-77447
but, the ARES II is a "7990" (two 7970 on a single PCIe x16 :))
  • AMD 7850 - 2GB GDDR5 256bits
  • gBANDWIDTH = 170.2 GB/s
  • gSHADERS = 1024 unified
  • gCPUoc = 1050 mhz
  • gMEMoc = 1330 mhz (x4)
  • gPIXELfillrate = 33.6 GP/s
  • gTEXTUREfillrate = 67.2 GT/s
https://linustechtips.com/topic/7299-extreme-ares-2-mini-build/#findComment-77451
but if you look in the front it is room for the ares and the drive bay i don't need;)
if you put the ares II rad where the 200mm fan is???
I am having problems with picture urls but this is the best i can find: http://farm9.staticflickr.com/8425/7...5abda406_h.jpg[/url=http://farm9.staticflickr.com/8425/7618295724_2c5abda406_h.jpg]
https://linustechtips.com/topic/7299-extreme-ares-2-mini-build/#findComment-77462
From memory no it isn't. The Ares 2 uses dual 7970 Ghz edition cards. There is a difference between the normal 7970's and Ghz editions.
https://linustechtips.com/topic/7299-extreme-ares-2-mini-build/#findComment-77463
https://linustechtips.com/topic/7299-extreme-ares-2-mini-build/#findComment-77471
One other key thing I forgot and should have mentioned it earlier; the Ares 2 is a tripple slot card. It will not fit in a mini ITX case.
Good point
still, we can mod the case to make it fix ;D
but yea (still, it be fun build it, with a mod mini ITX case)
  • gCPUoc = 1050 mhz
https://linustechtips.com/topic/7299-extreme-ares-2-mini-build/#findComment-77474
You wouldn't be able to - you'd have either all the IO ports on the motherboard to contend with or the structural integrity of the side panel to worry about.
https://linustechtips.com/topic/7299-extreme-ares-2-mini-build/#findComment-77476
finally got the picture thing right;)
keep in mind that the ARES II is not just long and 3 slots
it is also "more high" that normal
  • gCPUoc = 1050 mhz
https://linustechtips.com/topic/7299-extreme-ares-2-mini-build/#findComment-77477
I still think it is possible;)
one thing to keep in mind to, is that the case it is a bit mod
(the 2 slots whas mod to be a 3 slots just a bit)
  • gCPUoc = 1050 mhz
https://linustechtips.com/topic/7299-extreme-ares-2-mini-build/#findComment-77508
