Hello, recently i build my new pc but there is something whit the ram.I`ve got 2x4gb.When i start to play gta V on default settings, it avg 30fps but when i get in a vehicle and go fast, it start to drop the frame rate till 0 almost ... When i check my advace system care for the % usage it stays aways over 80% Why is the system struggle ? Please help :)
if anyone wants the pc specs:
CPU-AMD A10-7870K
GPU-AMD Radeon RX460 2gb gddr5
Mobo-Asus A88X-pro
HDD-WD 1TB
RAM-2x4gb Adata 1600mhz
PSU-600W Njoy 80+bronze
For the Picture-What is modify Memory ?
https://linustechtips.com/topic/729852-ram-problem/
default settings you mean? normal? high? and MAYBE your gpu is bottlenecking your apu...
Remember to quote me (or someone else), otherwise we won't going to recieve your answers...
PC Specs                   PCPartpicker full performance builds (from350$-1250$)
https://linustechtips.com/topic/729852-ram-problem/#findComment-9276281
