So I am installing my motherboard the MSI Z270 M7, and I was looking at the included M connectors one I know where going. However the JFP2 only have 4 pins and it doens't look like there should be more there, but the M connector have 7 pins. As far as I can see there isn't a port on the motherboard that fits the 7 pin (4 on one row, and 3 on the second row) M connector on the motherboard. It is labeled GND, SLED and PLED on one side and SPK+, BUZ-, BUZ+ and SPL-.
For some this is kinda silly question, but he last motherboard I had they just used 1 M connector and there are some years since last build, and I have been looking it up on the internett but found nothing.
Does this mean I am supposed to only use 4, or my motherboard doesn't use all of them.
again bit stupid but had to ask, thanks for answers in advanced
https://linustechtips.com/topic/729818-help/
